Mah resitrictions
  • TRUCKPULL
    replied
    Terry
    What about Offshore classes.
    We will end up with Full "P" & "Q" ETC boats with larger capacity batteries to get 4 1/2 Min..
    Or a 36" cat with twins and 10,000 per motor???????
    I have been fighting for almost a year to make my twin "P" Cat run on 10,000 max for Offshore - 4 1/2 Min.
    I finally got it running at about 55 to 58 for 4 1/2 min. using about 90% of 10,000.
    Larry
    Leave a comment:
  • photohoward1
    replied
    IMPBA does have a weight limit though. 24#. You quickly come up against it in an open 10s boat. So for the larger boats there is a Sudo limit. Terry while your at it what about the new HV batteries? How are clubs handling that issue? I have club guys buying them and then I explain if they travel they can't use them.
    Leave a comment:
  • Greg Schweers
    replied
    When NAMBA switched from 4.20 to 4.23. A 5000 pack is basically a 5100 to 5200 mAH. If you put 2 5000 packs in parallel, you're basically running 10200 mAH. So you might as well just throw out the milliamp rule.
    Leave a comment:
    replied
    Originally posted by RayR View Post
    Terry,
    i have recently been thinking about the same thing. Many batteries now at 5200 and greater. 2p puts us over the 10k limit.
    Agreed..
    makes the 10k limit hard to do with the new labels we see on our packs ... some not all
    Leave a comment:
  • JimClark
    replied
    I looked at 10000 mah 4s and 5000 mah 4s the 10K are about 8 ounces heavier
    Leave a comment:
  • T.S.Davis
    replied
    Doug, I'll give you a call on my way home.
    Leave a comment:
  • T.S.Davis
    replied
    I used to get it but not so much anymore. It's just something else to think about when choosing batteries too. I like to pick cells I can use for a bunch of classes. 5600mah packs would be really versatile.
    Leave a comment:
  • Doug Smock
    replied
    So does anyone have a legitimate reason to limit NAMBA class mah? Has anyone ever checked it at a race?
    Is it time to move on from mah limits in NAMBA? Opinions welcomed.
    No, no, yes.
    I'm glad you brought this up Terry. As you know Don and I had to re tool to race the Michigan Cup last year.
    You're right about racing in the IMPBA, capacity hasn't been an issue in any way shape form or fashion.
    I'd love to see it go away before the Michigan Cup. I really hated putting Zippy labels on my Hyperion batteries last year.
    Leave a comment:
    replied
    Ditch the limit....theres no way anyone would use 10000mah in a six lap heat...if people want to carry more (and more potential weight) , who cares...if anything it will just keep batteries happier.
    Leave a comment:
  • RayR
    replied
    Terry,
    Leave a comment:
  • JimClark
    replied
    if you could use 10000 mah you could get 2 heats on one pack therefore cutting down your charging and number of batteries .hough the first run would probably be better than the second run.
    Leave a comment:
  • T.S.Davis
    started a topic Mah resitrictions
    Mah resitrictions
    Okay, this will be fun. Brian's first "what fer?"
    I know why we included MAH restrictions back when the Lipo cells were proposed. That limit was included to appease the doom and gloom "we're all gonna die" gang. Some also thought that all classes would be dominated by massive mah. IMPBA went with max charged voltage but no mah limits. So if you had a pair 5200's for a class you were still fine but if you race NAMBA.....hosed. Best I can tell, it hasn't made a lick of difference to IMPBA. I asked and I've raced both organizations.
    http://forums.offshoreelectrics.com/....php?53696-Mah
    See....I did ask.
    My opinion has changed over time. I was the anti-big mah camp. All I could see was the cost of 2P and a speedo that could turn a million amps. Tech has evolved and become much more accessible. I think now that with the length restrictions you can only carry so much weight before you've built a submarine instead of a boat.
    So does anyone have a legitimate reason to limit NAMBA class mah? Has anyone ever checked it at a race? What a pain in the a$$ if we did.
