P-Limited Motors - Im going to jump on the hot seat.
This is a sticky topic.
  • Ken Haines
    Racer
    • Jul 2007
    • 647
    #451
    Everyone,
    We are all certainly aware that NAMBA and IMPBA rules differ on the P-Ltd ESC"s allowed.
    I am actually not bashing IMPBA here as I understand the thinking very well.
    The reason I bring this point up is that most likely IMPBA will follow suit on the motor options
    being discussed here. Again, I do not have inside info here, I am only making that assumption.
    (Btw...I have not spoken to Doug Smock since the Michigan Cup.....I don't even like him that much)......lol
    But the thought came to me this morning..... our motors probably need to survive the AQ ESC.
    Let's all ponder this for a moment.....will the TP motor burn up one of them on a standard race set-up ?
    If so then this may be an issue.
    Your thoughts ?
    TenShock Brushless / Pro Marine
    INSANE Boats / Rico Racing/ Castle Creations
    2023, 2024 NAMBA & 2018 IMPBA FE High Points "National Champion"
    • RayR
      @SiestaKey.calm
      • Jun 2007
      • 1518
      #452
      Ken,
      As I understand it, IMPBA does not have an ESC restriction. In fact, there is no defined P-Limited class in IMPBA. The folks in D13 do have a restriction for thier defined P-Limited class.
      • TRUCKPULL
        • 2971
        #453
        Originally posted by jaike5 View Post
        Or you will have p - limiteds like Larry's with high amp hvdra's with massive cap banks and other internal mods to be able to swing outrageous prop's. his p- limited whip is really quick should be in p, and be faster than most.
        Cheers, Jay.
        Jay
        First lets get your facts right.
        In my LSH (p limited Sport Hydro)
        I run an old Castle Barracuda 80Amp ESC not the 120's that I modify for N2 & P classes
        UL1 motor
        Modified cut down 440/3 prop--( NOT outrageous )
        and my cut down modified WIP 26 7/8" long ( I also use this hull in N2 class)
        You have the same Hull that you bought from me, but don't use it for LSH ( why not??)
        Larry
        • Ken Haines
          Racer
          • Jul 2007
          • 647
          #454
          Originally posted by RayR View Post
          Ken,
          Then I stand corrected...thanks Ray
          • jaike5
            • 561
            #455
            Larry,
            I know you us the same hull in N2 as lsh , that's why Ray said You just swap out the motor, don't know where the barracuda came from.... although I'm sure you have one or 5. The props you said you use are cnc props from Europe , you got me some as well. this is why we need stock esc's, along with the motors, to keep it real.
            Cheers, Jay.
            • Darin Jordan
              • 8332
              #456
              I'm sorry, and I don't want to derail this thread from its intended conversation, but there is no such thing as a "stock" ESC.
              It's a flawed concept, that doesn't restrict anything, especially when the Pro Boat RTR now have 120A escs.
              Darin E. Jordan - Renton, WA
              • Doug Smock
                • 5264
                #457
                Originally posted by Ken Haines View Post
                Everyone,
                Your thoughts ?
                Well Ken I just barely tolerate you so I guess it's all good. I guess you don't need any shafts hardened??
                Smart IMPBA clubs will be looking at what motors NAMBA is running. They know they need to make it easy on racers to crossover.
                The districts that have ESC restrictions can adjust easily if they want/need to. I was able to make two phone calls and open up the Spring Nationals to any ESC when those yahoos from Michigan showed interest in attending.
                FWIW I expect to see a change in the ESC language for 2016 in D13. However, I imagine there may still be a limit. We'll see in Nov.
                MODEL BOAT RACER
                IMPBA President
                IMPBA 19887L CD
                NAMBA 1169
                • TRUCKPULL
                  • 2971
                  #458
                  Larry,
                  Cheers, Jay.
                  Sorry Darin
                  This is my last comment to Jay here.
                  JAY get your facts right before you comment.
                  The Custom props from Europe are for N2 only NOT LSH.
                  My LSH props came in RAW form from OSE
                  Larry
                  • TRUCKPULL
                    • 2971
                    #459
                    Darin
                    I have been running the (I guess the older one, Gray can with blue end bells) DYNM 1500KV motor in "P" spec MONO and Offshore
                    The only specs that I can find on it are
                    6 pole
                    2 turn
                    Can you tell me what wind it is "Y" or "D" ??
                    also what differences are there to the new DYNM 3835 - 1500KV ??
                    Dynamite also has a DYNM 3910 - 2000KV motor
                    Would this fit into the "P" spec class??
                    Larry
                    • jaike5
                      • 561
                      #460
                      Sorry, my bad. The aqua craft esc that ken mentioned. comes as stock/standard equipment with UL-1 rtr out of the box for spec class.
                      • Darin Jordan
                        • 8332
                        #461
                        Hmmm... Doing some more searching...
                        Here is an interesting consideration from Neu that might fit.
                        It's 36mm x 57mm, 205g, 1850KV.
                        Will have to test to know:
                        Here is the description:
                        The 1410/2Y/SE is designed as a lower cost version of our popular 14XX series motors. It has a little smaller rotor diameter rotor but to makeup for that the stator is a bit longer. The Kv for this motor is 1850 with a no-load current of 1.4 amps. Weight is 205 grams. Diameter is 36.5mm and is 58mm in length. The output shaft is 5mm. We are offering a limited time special on these motors of $99. This motor is a good match for the MidiFan running 6 or 7S and drawing 60-80 amps with thrust in the 70-90oz range. The 1410/2Y also will make a prop plane move right along too with a 8x5 prop and a 3S battery it will draw 50 amps and with 7x7 prop 45 amps.
                        • raptor347
                          • Jul 2007
                          • 1086
                          #462
                          50mm stator length as well.
                          Brian "Snowman" Buaas
                          Team Castle Creations
                          NAMBA FE Chairman
                          • Darin Jordan
                            • 8332
                            #463
                            Price is right too! $49.99...
                            I inquired with Steve and he can have them made in additional winds to cover the required KVs also, though this is the only one he currently has in stock. He has over 100 of them in stock currently.
                            Would be nice to have another SOLID supplier available.
                            I've ordered one of these just now and will include them in the testing.
                              • 9438
                              #464
                              I've mentioned this motor numerous times and Terry thought it would not cut the mustard. I like it.
                              • Darin Jordan
                                • 8332
                                #465
                                I'm working hard (and spending a LOT of $$$) in order to gather facts that will cut through any speculation.
                                I'm pretty sure I'm the only one who has actually gotten INSIDE these motors (and will shortly with all these additional motors), to actually physically measure and compare.
                                When this exercise if finished, we'll know exactly what we are presently have, and then we'll know what might compare.
                                One thing that is already clear: we do NOT have 36x60mm motors... Every one of the currently approved motors have the same 31.49mm stator and are all considerably shorter than the TP3660 motor I have here. All the currently approved motors are 36x50.
