More limited motor discussion
This topic is closed.
  • T.S.Davis
    • 6266
    #196
    That's the way I remember it too Mike. TP actually lists a V1 and V2 version in the data sheet.
    There for a while if you ordered a Neu and they didn't have the right can on the shelf they just stuffed your order in the can they had available. I have a crazy looking 22 series like that. There's about 3/4" of dead space in there.
    Noisy person
    • T.S.Davis
      • 6266
      #197
      Hmmm About 8mm shorter on the mod 1515 2200kv but same weight. Not sure what to make of that.
      Noisy person
      • HTVboats
        • Jun 2011
        • 936
        #198
        Maybe to simplify things the rules would incorporate and allow an FE Director and a select committee of say 4-6 actual FE racers could review and update yearly an approved motor list staying in the 36X61 mm range. Right now the list is out of touch with available motors. That way review is built into rule structure.
        Mic
        Mic Halbrehder
        IMPBA 8656
        NAMBA 1414
        • Ken Haines
          Racer
          • Jul 2007
          • 673
          #199
          Originally posted by longballlumber View Post
          I pulled this attachment from the measurements thread.
          I was looking at the lengths that Dave provided a little closer this morning. Did you notice the NEU 1412 3D is 61mm long. The other 1412's are 55mm long, but they all nearly weigh the same.
          The other thing I noticed was the his 1409 2Y is the SAME length as a couple of the 1412's
          I seem to recall at least 2 (maybe 3) where TP shipped or manufactured cans of different lengths.
          Just an observation.
          Hi Mike,
          Just ran the 1412-3D(61mm) Sunday that I bought from Dave (brand New), actually had not even gotten
          to fill Dave in on these results yet. I had my same set-up and prop as when I run the Dynamite 1500.
          I do not want to give away my whole set-up, however I probably have 50+ heats on my P-Ltd mono.
          That 1412-3D is 1650kv. It ran pretty much the same speed as the Dyn 1500 I know for sure
          because my son's boat is absolutely identical same speed too. We ran pretty much neck and neck on the
          straightaways just like when I run the 1500. This dissappointed me a little as I had hoped it would have
          been slightly faster with the 150Kv addition. When I was done with a 1 mile run (8-Laps on 1/8th course)
          and brought the boat in it was really hot and now the windings are pretty brown kind of half smoked.
          I realize this is not absolutely technical, but kind of proved not to be a better motor than the Dyn 1500.
          I will note that the 1412-1.5y does seem to be better than this 3D. Could be the old Y's run cooler and
          more efficient than D's theory.
          Hope this helps, just wanted to provide some info for you....yer Lordship....lol
          Thx,
          Ken
          TenShock Brushless / Pro Marine
          INSANE Boats / Rico Racing/ Castle Creations
          2023, 2024 NAMBA & 2018 IMPBA FE High Points "National Champion"
          • dethow
            Wired Racing
            • Oct 2014
            • 1500
            #200
            Mike and Terry,
            I know guys... there are some weird things there. For that reason, all of the Neu motors I have will be coming to the meeting on Saturday so that Mike can check all the measurements and weights.
            I no longer have the Spec 1415 that was 70.1 mm long. That motor was sent back to Neu as a guinea pig. I have asked Steve Vaccaro to provide some measurements on that motor (since he stocks them) for some verification on what I had.
            Steve, if you are seeing this... there is a list of additional motors on the measurements thread.
            I also no longer have the 1409 or 1410 motors. I believe the explanation on why some of the 1412 motors are in a similar 55mm long can, like the 1409... is because Neu made a slight mistake when building the 1412 1.5Y and 2.5D motors. They were ordered to be at the spec 61mm and one day they called and said there was a mistake made on the cans and would it matter if they were under 61mm. I didn't care as long as they were under 62mm. You know? Anyway… I think those 1412 motors basically got crammed into what they normally use for the 1409.
            Those 1412s coming at that short length is what sparked my thought of the 1415 being cut down to fit 62mm. So Neu then made a mistake on the 1412 3D motors and shipped them to me at 68mm long. When they had me ship those back for correction I used the opportunity to have them cut down the 1415, I already had. Since they were already going to be setting up machinery for cutting about 8mm out of a motor... Why not? It worked so I placed an order for additional 1415s.
            That’s my story and I’m sticking to it!
            Have fun with that....
            • T.S.Davis
              • 6266
              #201
              I'll look through my stockpile. I pitched a bunch of motors late season. Mostly SSS motors loose.
              Noisy person
              • Steven Vaccaro
                Administrator
                • 8934
                #202
                your right, many motors in diff cases. Another reason not to use my motor list idea.
                Steven Vaccaro
                • Darin Jordan
                  • 9446
                  #203
                  Ken, if you tried to run a 4-Pole, 1650KV motor, using the same prop as the Dynamite 1500, 6-Pole motor, then I can explain your "brown" windings... Wrong prop for the job, my friend. :) Definitely not "apples to apples".
                  Get into Brian's "magic prop box", and the results would have been different. I'm certain of it.
                  Darin E. Jordan - Renton, WA
                  • T.S.Davis
                    • 6266
                    #204
                    Nobody listens to us Darin. Haha
                    Noisy person
                    • Doug Smock
                      • 5359
                      #205
                      They're learning...
                      MODEL BOAT RACER
                      IMPBA President
                      IMPBA 19887L CD
                      NAMBA 1169
                      • NativePaul
                        Greased Weasel
                        • 2770
                        #206
                        An outsiders view here, take it or leave it.
                        It seems that you are trying to limit power by using the motor as a fuse, and are having issues with people pushing the motor too hard and blowing them, motors changing spec within production, and going out of production, but it looks like if you open the motor spec up
                        to allow decent non RTR motors, you will allow full on P power with it, which is likely to kill either the limited or the full P class.
                        Have you thought about limiting the power electronically, instead of with a very expensive fuse? https://neumotors.cartloom.com/store...imiter-2017-18 From what I gather 1KW is a decent but fairly conservative power for P Ltd, that should not result in lots of blown RTR motors, even if you didn't get one from "the magic batch", you could open it up to any motor, and while expensive books will have a slight efficiency advantage, the difference will be a heck of a lot less than the difference between 2 people with the exact same motor, one of which runs conservatively as they need it to last for years, and one who poo uses the limits as they don't mind burning one now and again.
                        I haven't used the above device, I just saw it and thought of you guys, maybe it is the answer to your prayers, maybe due to the peaky nature of boat power vs the steady power of an aeroplane it can't work, or maybe New could do some mods and make it work.
                        In Naviga are just going away from using our batteries as fuses and are using electronic energy limiters instead, which is perfect for us as we have a set run time, but with the right energy limit set could work for you too, if boats are too peaky for a power limit to be feasible. There are 3 manufacturers of boat energy limiters, and they have 2 years of national level testing behind them, but are just being legalised internationally this year. China race to Naviga rules too, so I expect we will see an energy limiter come out of China at a lower price point than the European made ones before too long.
                        • Doug Smock
                          • 5359
                          #207
                          Hi Paul,
                          Yes sir ''The motor is the fuse" mentality is what got this party started. Current limiters and fuses have been beat to death through the years.
                          https://forums.offshoreelectrics.com...or+is+the+fuse
                          https://forums.offshoreelectrics.com...-AMPs-Thoughts
                          https://forums.offshoreelectrics.com...tor-discussion
                          https://forums.offshoreelectrics.com...n-the-hot-seat
                          https://forums.offshoreelectrics.com...lines-for-2015
                          And it goes on and on......
                          Mr. Ball ( Yer FE Lordship) is on a path that may be viable and long lasting. If he finds that it's not the case my hope is that he advises the IMPBA BOD to run, not walk away from this. Many of us have been managing these classes just fine. Without a National Rule set!!
                          Originally posted by raptor347 View Post
                          I've given this some thought over the last couple days. Maybe P-ltd has run it's course.
                          We've had a good 8 year run with it up here in the PNW. I think the rest of the country has done pretty well too. We could just let it die and return to open motor racing nationally and let the local clubs run what they want. With the historical experience of LSH and P-ltd, another option is flush this rule set and come up with something a bit more stable/flexible using that past experience. What stable/flexible means is certainly open to interpretation.
                          Having watched and participated in these discussions for years now, it might be the most healthy move for the hobby. As a recipient of some of the mud slinging, it certainly makes me wonder if it's worth the continued effort to keep it alive.
                          Until someone sits down and writes up a rule proposal and it passes, it is what it is in NAMBA. At this point, I really don't care if the class continues or not. I will say that the manner in which these discussions carry on isn't good for the hobby in general.
                          It's hard to argue with Brian here. When is enough, enough?
                          Don't forget there is more of the above here http://www.rumrunnerracing.com/feforums/index.php
                          And here...http://www.intlwaters.com/index.php?act=idx
                          MODEL BOAT RACER
                          IMPBA President
                          IMPBA 19887L CD
                          NAMBA 1169
                          • Ken Haines
                            Racer
                            • Jul 2007
                            • 673
                            #208
                            Thanks Darin......I guess when I hear Terry talking about the 6-pole advantage I need to listen better &
                            put more thought on the subject. Btw Terry or Darin, which motors brands are currently 6-pole ?
                            Feel a little dumb now, but guess I have learned something, otherwise it would have had a pretty valid test.
                            To others reading this do not be confused about us having burnt motor issues, we are not, it was a test
                            and I definetely was not worried about the outcome, just wanted to drop something into my existing set-up
                            so that I did not waste this spring re-testing props. Thought the results would lessen the fears of the 1412's.
                            Great thread....lets keep the positive energy going on this and
                            hopefully fix the little bump in the road and fly with most of the
                            original proposal plus the soon to be determined weight limit revision.
                            Then lets get back to racing !
                            • Darin Jordan
                              • 9446
                              #209
                              Doug,
                              With all due respect, P-LTD is the biggest set of classes out there. If not for this format, exactly how many FE racers do you think you'd actually have??
                              I know it's a pain right now, but it's hard to argue that the basic idea is working. You just need to stop focusing on the chaff, and focus on the actual root of the matter.
                              Sorry, but it's silly to just say "let it die", when there are entire clubs, and a good chunk of the National FE program, subscribing to this format of power systems.
                              • T.S.Davis
                                • 6266
                                #210
                                Doug, if you want to have an FE nats (some of us still like those) moving forward you have to include the power level that brings the boys to the pond.
                                You also need Joe new guy that's surf'n the web, to find the IMPBA rule book, sift through and find classes that there are actually boats running in. Heats to land in. So......racing can happen. Right now, a guy opens the book, see's 4 pages on brushed N1 motors and figures that's a great place to start. "Hey, I got a whole box of those old motors! Woohoo!" Or he builds a 2s open boat thinking it will be a cheap way to get going. Been 8 years since I heat raced one. I have 6 on the rack still. Or he could maybe build a 70mph P rigger on the cheap. Good place to start? Open racing is fine for some but based on the many guys I've personally trained/mentored/whatever ya call it..................P is a horrible place to start. I've got guys that have raced for a few years now that can barely handle limited.
                                Doug and I both agree with Brian. This is the path Mike is currently helping us navigate. I'm more confident than I have been in a while that we're getting somewhere.
                                Noisy person
