41'' Fantasm Video
  • Rocstar
    Joel Mertz
    • 1536
    41'' Fantasm Video
    Just messing around on 6s...
    Nice and solid running there Joel. 1800's in there?
      Did you ever give it full throttle? J/J! Nice running g there and smooth! Good job. Hope mine runs that well!
      • Rocstar
        Joel Mertz
        • 1536
        1680s. I put the longer rudder on for sport. Spinning 648s and after 4 minutes, nothing too hot. Sometimes it's fun not worrying about blow overs.....
        • Rocstar
          Joel Mertz
          • 1536
          This is with the 1800s on 6s...
            Ok so now that I see I am in the ballpark with you guys, which props on the 1800's Joel?
            • Rocstar
              Joel Mertz
              • 1536
              I think they were 447s....
              You've seen this before, but this is the 1680s on 8s running 93mph through the traps.
              • Rocstar
                Joel Mertz
                • 1536
                Might as well put all the videos of this one running.
                This was with the 1800s on 8s. Harder to keep her flying level at these speeds. This was the crash that took out the big twin 300a controller when the front seam of the hull split.
                Record hang time though!
                • kingwrench
                  • Sep 2011
                  • 221
                  Joel I have the same hull the same issues. Ran 78 just burping it, the bottom of the hull was delaminating off in sheets. so she is shelved. Prob going to pull the NEU's and re rig make it a cruiser. not happy with the CF work on this hull.
                  Top Gun 2011, "current problem" 88MPH. Top Gun 2014 "Marine One" 99 MPH. bet speed to date 125 MPH
                  • Rocstar
                    Joel Mertz
                    • 1536
                    It seems hit or miss with the quality of the CF version. I've built two that are holding up well (other then a split seem from a 90+ crash) so far. I've also heard of the same problem you're having from another member. We are pushing these hull pretty hard though.
