Nice... what did you change? That's 12mph quicker than your most recent video... crazy
The HV Fantasm performance vids
If I wait till the sun drops behind that mountain I can see the whole lake well. It was good just as I was bringing the boat in. End to end would be enough room at this lake. My other spot has gotten too low now what with all the waterski crap in it.Originally posted by kfxguy View PostAwesome! You need a longer area to run in!
I just upped the props to 1915's that Chris cut to 47mm. Just a mm bigger than the 18's but...Originally posted by dmitry100 View PostNice... what did you change? That's 12mph quicker than your most recent video... crazy
That's sick shawn, you run 12s with etti 120 or 220hv?
The 220's Mike. I had the 120's in there to start way back but felt they were being pushed so I upped them. I really need to log some amps again and see where I'm at now. I know you were interested, me too.Originally posted by iridebikes247 View PostThat's sick shawn, you run 12s with etti 120 or 220hv?
I haven't ran the ettis only the tp motors which have been amazing. BTW the props, they're a counter rotating 1915 set? I haven't seen them.
How are you recording speed? A GPS can't get a signal inside a carbon fiber hull/deck. What is that software that gives you the dashboard display?Originally posted by srislash View Post
I see. From time to time I have been to their web site. However, I could never figure out exactly what components to pick. Sounds like you are happy with the system. Could you list your configuration? I use a Garmin Forerunner 201. I have to tape it to the fore deck with hatch sealing tape. It doesn't record anything, but does show max speed for the run. On F/G hulls I just stuff it inside.Originally posted by srislash View PostI run EagleTree with the GPS Expander mounted outside the hull. I wasn't running the RPM sensor as I just had to change the collets out and did not install the sensor magnets on them.
I had lost two of those doing that. The eLogger V4 does most stuff you could need(volts,amps and such). The GPS expander is a real good addition, just waterproof it and put a piece of pool noodle in it then you can mount it outside. The Hall effects sensor with magnets measures the Real propeller rpm but is a pain to rig(I could help with that).
This should take care of all your needs for getting more speed from the data.
I'm in the process of ordering myself a set of UniLog2. Looks to be a decent and thorough system. Supports up to 400 amps. And has rpm sensor that connects directly to a phase.
Not badly priced either... makes a decent option aside from the Eagletree.
Whats the max amps the eagletree current sensor supports?
150 @ 75volts without modifying it Dmitry. The Unilog is a real good choice. If I wasn't so used to ET I would go that route.Originally posted by dmitry100 View PostI'm in the process of ordering myself a set of UniLog2. Looks to be a decent and thorough system. Supports up to 400 amps. And has rpm sensor that connects directly to a phase.
You can simply run a jumper wire on the ET to get it up to 300 amps.
I had one of the old style ones twist and slip of my 1.6 3 blade props last week. I put the new ones on and no problems now(once I did get them tight enough).Originally posted by dmitry100 View PostLast night an MBP collet slipped when I tried my 1715's. Had them tightened really well too. Do your collets hold up fine when spinning those bigger 1915's ?
I did solder up the flex ends before the new ones went on.
