Spartan doing 57 mph
  • Rumdog
    • 6453
    Originally posted by stolioni View Post
    i was looking at a lower kv motor that could handle more volts so i was thinking higher volts more rpm? two 4s batts or even two 6s but i'm pretty sure i would need a hv esc to handle it ... i know that seaking makes a 80a hv that would handle 160 or 180a bursts but it doesn't make sense to me because if you were to run two 6s batts wouldn't that fry the 80a hv esc?
    If you can get your hands on a CC/Neu 1717... Great motor, perfect size for the Sparty. 6s2p is what you want, not 2x6s packs in series. A Turnigy or Seaking 180 will do quite well with that motor as well.
    • Rumdog
      • 6453
      Right here in this thread: http://forums.offshoreelectrics.com/...ight=1717+sale
      Brand new.
        • 9479
        I'll see if one of my CC1717 motors will fit in my Spartan..
        right now I have a CC1520 resting in it
        • Rumdog
          • 6453
          Sweet! Hopefully she fits. May have a clearance issue with the O.D.
          • keithbradley
            • 3663
            #35
            Why is it when a few guys see someone throw a bunch of volts at a high kv motor, and it goes REALLY fast for a few vids that everyone all of a sudden thinks it is a good idea?
            In fairness he did say lower kv.
            To the OP:
            The idea of running higher voltage/lower kv is to reduce current draw and run bigger props. Your setup will generally run cooler when acheiving the same RPM, and you will have longer runtimes with the same mah.
            You have to keep in mind the room you have in the hull and the weight of the boat with all those batteries though.
            www.keithbradleyboats.com
            • Rumdog
              • 6453
              #36
              Yeah, that was badly worded on my part too.
                • 9479
                #37
                it fits, but I dought a cooler is going to work with it using the stock mount??
                • JPriami
                  N4FOX
                  • 1675
                  #38
                  Bet the 1717 and a jacket will fit
                    • 9479
                    #39
                    what cooler do you know?
                    • GeoVW72
                      • Jun 2010
                      • 258
                      #40
                      This one
                      Team Boca Bearings
                      S&G Design
                      • Rumdog
                        • 6453
                        #41
                        You'd better support the end of that bad boy. All that weight hanging from a plastic mount may not last too long.
                          • 9479
                          #42
                          when I mounted mine that sucker was heavy
                          • mannytx1
                            Fast Electric Adict!
                            • Oct 2012
                            • 99
                            #43
                            Diameter reduced, back- cuts, balancing and detongueing , harpening, 42x55 -- 40x55
                            connector 4mm Gold
                            cooling hose 1/4x.170 O.DxI.D
                            4S 39.2mph
                            5S 48.7mph
                            6S 57.5mph
