Ul1 4082 build
  • Luck as a Constant
    Make Total Destroy
    • Mar 2014
    • 1952
    Ul1 4082 build
    Your run times might be kinda short, but the kv isn't absurd or anything.
    • MGORMAN
      • Aug 2014
      • 44
      if I can get 2-3 min runs I'm content. The room in this hull is small so I couldn't go with a lower kv and higher volt. So I went higher kv lower volt..I mean if I'm correct so hopefully that motor will pack a lunch on 4s
      • MGORMAN
        • Aug 2014
        • 44
        Anyone have any prop advice for these boats.? 2-Blade ? 3-Blade ? Size ? Thanks.
          Make Total Destroy
          • Mar 2014
          • 1952
          I liked 3 blade props on it.
          X440/3 and my favorite the grim L40/57/3.
          Of course that one sucks to balance and sharpen, and is useless unless it's done nicely
          • MGORMAN
            • Aug 2014
            • 44
            Thanks ! ^
              Make sure that LONG motor has plenty of rear support, may be a wedge under the can? The stock motor mount/bracket is easy to flex and if it is bent, the alignment of the collet and cable will be out and you have excessive binding in your drive line.
              • MGORMAN
                • Aug 2014
                • 44
                Yep. Got support under the motor to help take stress off the bracket and keep the sag out hopefully. Thanks for all the tips everyone. !
                • kevinpratt823
                  • Aug 2012
                  • 1462
                  Personally I see no real advantage on the oversize motor btw. You'll be turning close to the same rpm as stock, the only gain is torque, which is only useful if you can run bigger props. IME the handling suffers greatly with anything more than the 40-45 mm props at 1.4 pitch, it really starts to walk the rear end, and there's not much rudder there to counter it.
                  Also, you can support the motor all you want, my concern would be that the mount will rip the hull open on a hard hit because of the weight. It's also going to be real tough to get on plane with all that extra weight.
                  Sent from my SM-G920V using Tapatalk
                  My private off road rc track
                  • MGORMAN
                    • Aug 2014
                    • 44
                    Kevin,
                    Thanks for the input. I would like to just see how this works..By the way your dirt track is pretty awesome.!
                      I have had to bend the motor bracket back to its original shape EVERYTIME I flipped my boat, and that's with the stock motor, I got so tired of it and made my own mount. The base of the mount is to spread the load as the floor is very flexible. My boat is not the so-called "first" batch, the turn fin area weakness had already been addressed, so may be later version ( if there is such a thing) had also addressed the flexible floor.
                      It is rock solid and I can grab the boat by the motor w/o worrying any alignment issues.
                      • MGORMAN
                        • Aug 2014
                        • 44
                        That's a sweet bracket. What's holding it up.??
                        • MGORMAN
                          • Aug 2014
                          • 44
                          Style bracket ***
                            DSCN5805_6140.jpg DSCN5808_6143.jpgDSCN5810_6145.jpg DSCN5825_6160.jpgDSCN5830_6165.jpg
                            Style bracket ***
                            TFL motor mount. $3.00 only, lol.... http://www.kintecracing.com/Motor_Mounts.html
                            Scroll down patiently and you will see it.
                            Note that this is the only mount that does not increase the width of the motor, the other popular mount ( cooler mount with side rails) is so wide that you won't be able to fit any batteries in it.
                            • kevinpratt823
                              • Aug 2012
                              • 1462
                              I had those issues also, Tim, bending the mount, and I remember how weak the floor felt, hence my concern with a heavier motor.
