Cap banks - the pre-emptive answer
This is a sticky topic.
  • drwayne
    • 2977
    #346
    That is good news..
    does your esc run cooler with this setup ?
    belated reply .. lol ..
    correct assembly of caps will run the battery and esc a little cooler...
    -too many additional caps ( eg 300+% of original ) will punish the battery
    -QUALITY rubycon high yield, low esr caps are 16v, 35v or 63v ......... intermediate voltage rates are provided by electrolyte combinations.... ergo avoid the 50v
    despite my best attempts at reconfiguring mail filter settings and such.. I fail to rcv notifications from OSE
    tag me on FB and I'll pop back over for a chat
    Wayne Schutte. 1,394 likes. eidectic memory. Overqualified smartarse. into electronics, robotics, technology, and sarcasm.
      • 9479
      #347
      I was curious at how Travis's boat was running with his setup
      I run caps on all my setups even helis
      • dmitry100
        • Mar 2015
        • 1264
        #348
        drwayne:
        Would you say of caps like these which, little did I know before ordering, are Made in China?
        https://www.digikey.com/product-deta...1713-ND/756229
        They seem like a good brand. This particular new model is some new type of electrolytes. Thought they'd be Made in USA... but Made in China (surprise!) after I received my order of a bunch of them lol.
        Btw, any particular way of knowing whether you have too little or too much caps? You say 300% of original would punish the battery...
        • CraigP
          • May 2017
          • 1464
          #349
          Here's my new Cap Bank Board for my 8s system. There are 3 types of caps, Low Z large electrolytic, very Low Z polymer electrolytic (smaller cans) and the surface mount MLCC caps, side pic shows them the best. EC5's are directly soldered to facilitate hookups to battery pack (inside set) and ESC (outside set). All components are directly soldered to 0.025" copper strips, providing very low inductance and resistance contributions. Looking forward to putting it to use!
          • TRUCKPULL
            • 2971
            #350
            Nice work on the Cap Bank Board.
            My only question is the size of your plugs for a 8S system?
            Larry
            • CraigP
              • May 2017
              • 1464
              #351
              These are EC5's... I'm looking for a little resistance. An electrical circuit is made of up R, L and C. It's like good chili, need the right balance! But the R is still ridiculously low, about 0.0025 at power and temp, per connector. So that's 0.0025 X 90A X 2 = 0.45V That's the roll off I'm looking for.
              • drwayne
                • 2977
                #352
                Nice.
                But not correct.
                Under current draw the weaker/lower f caps will inhibit the larger.
                EC5 plugs are ok up to around 100A max.
                Keep at it.
                • CraigP
                  • May 2017
                  • 1464
                  #353
                  The reason the separate capacitors are used is based solely on frequency response. At motor fly back frequency, the MLCC ceramic cap is dominant. The polymer cap just helps to extend the bulk capacitor's frequency response. The caps don't get in the way of each other, they react at given frequencies. Don't want to get into an EE battle here, been designing motor drive circuits since the '80's, so very respectfully, I have to rely on my experience.
                  I am working with a 100A Max circuit. Expecting currents of 88-94A, that's what my target prop size is for.
                  • drwayne
                    • 2977
                    #354
                    Keep us updated
                    • CraigP
                      • May 2017
                      • 1464
                      #355
                      Tested the boat with and without the Cap Bank in there. The ESC came in with it showing 142 degrees F. A might warm, but not crazy hot. I put in that Cap Bank I made and the ESC dropped to 112 deg F. I was using more part throttle on that run as I came into the shore. The TVS's read 146 deg F, indicating that they were clamping the spikes well at the 34V level. Those parts can take that temp all day long.
                      The main Electrolytic caps (aluminum, low ESR) were showing 118 deg F. The liquid polymer caps were showing about 116 and the ceramics were the same temp as the copper conducting rails, 108 deg F. Overall, I think I'll try to get this unto a water cooling plate to see if I can conduct some heat out of the rails and reduce some of the temp on the bulk capacitors.
                      The test results for me prove that leakage inductance switching spikes are the culprit of part throttle ESC temps rising. The TVS is a very good part to keep it from the ESC, but these parts will get warm. I left the leads long on those parts on purpose, to act as heat sinks. The copper rails are the hottest right under the TVS's.
                      Next project on my list is to design and build a PCB for this Cap Bank and include a uP that will read the current of the battery system. The throttle signal will enter the uP and will pass thru unfettered if the system is running below the current limit set by some rotary dip switches. If the current goes above, the uP modifies the throttle signal to the ESC by effectively reducing the throttle signal, thus clamping the current draw of the system. Would be great to test upper limit setups and protect the equipment from failure. Couple that with the Swordfish ESC data logger, and you'll see the current limit come in with the reduction of the throttle signal accompanying it. The TVS's need to work, before this scheme will work. I think I have a good foundation to move this heat into a more manageable part of the electrical system and add a very valuable new tool with the current limiter.
                      • drwayne
                        • 2977
                        #356
                        Good effort.
                        Current limiting = power limiting, which is contrary to what this thread is about.
                        Build a better bank without limitations and get back to us.
                        Or refer to the specs orovided earlier , and pkay happy.
                        Regs
                        W
                        • CraigP
                          • May 2017
                          • 1464
                          #357
                          Yes, current limiting IS power reduction. But this would be an effective tool to get the setup right, so you can take the current limiter off and have confidence what power levels you will be running. I want to use it in tandem with the data logger and fix the set up so it runs on the power budget.
                          My end goal is to master the use of high voltage packs and make power with higher V, instead of higher A. This reduces the stress of the entire electrical system and helps to prolong battery life, since the current draws will be lower. But these BLDC motors are most unforgiving in trying to reach that goal. I want a tool that will minimize my electrical failures. I see it as a perfect tuning tool to reach no current limited AND no broken parts! I ain't made of money Doc! Thanks for the advise, hang in there with me...
                          • Steven Vaccaro
                            Administrator
                            • 8724
                            #358
                            Well done and great idea.
                            Steven Vaccaro
                            • drwayne
                              • 2977
                              #359
                              A thing with power availability. . The nore there is, the more people will push those limits.
                              With esc now capable 12s+ 300A+ , we need support the higher end demands of this market also..ETTI 5x35v1000uf banks suits most every 6s or lower setup.
                              Access to higher voltages leads to higher amps and the associated expectations of more of what this sport is about -> Fun .
                              What i detailed initially catered more the upper end of our hobby, and although taken up by lower cell count runners, that wasnt the aim. .
                              Latest battery construction generically support more kwh than our 90%+ users demand...
                              I see 90%+ of this hobby as plug and play experts .... Lol
                              Indubitably there are refined capacitor arrays producable for independant applications ..
                              This thread started as an introduction to a generic idea supporting the high end users who had clouded thoughts over unexplained repeatable failures :grin:
                              From there this has grown into a long diatribe... which is good for the hobby !
                              Stay in touch ... :)
                              • CraigP
                                • May 2017
                                • 1464
                                #360
                                Those that want to stay abreast of battery tech and amperage capabilities will have to come to terms with the problems associated with switching so many amps. 1-1/2" of #10 wire is enough inductance (about 0.8uH) to really start causing problems. 12s at 300A, crazy KW levels in such small form factors! But the larger classes (1/8 and 1/6 scale) could certainly use the power.
                                My goal with the DF33 Hydro is to achieve WOT turns, in race water and run about 60-65MPH on the straights. Above that, and it gets out of my reaction capabilities, though I'm sure some young bucks got the reactions times... I just turned 60, so I'm not what I was in the old nitro days. But I love this stuff Doc, God knows I love it! Keeps me young
