Turnigy 180 cooling upgrade
  • viper1
    • 219
    #61
    Does the Tygon tubing give enough flexibility?
    It does for me Steven, please define "enough" ?
    Might be interesting to know that after I cut my hoses to length, I throw them in a bowl of very hot water. They gain some flexibility and seem to keep this even after cooling down. A better grip on the water nipples as well.
    Wisdom is knowing how little we know
    • Steven Vaccaro
      Administrator
      • 8934
      #62
      thanks for the info
      Steven Vaccaro
      • twissted
        • 896
        #63
        I have these esc's running in my 42'' cat pushing 3674 2200kv. I have read that you can run them on 8s. I would like to try this. I have 1S-8S Lipo Battery Tester Low Voltage Checker Indicator LED Buzzer Alarm RC
        $(KGrHqYOKpMFG6z)Qn85BR)7Vmu3Z!~~60_57.jpg I bought a pair of them.180 amp esc turnigy 007.JPG180 amp esc turnigy 008.JPG
        I want to know what you think and this cooling that is done because of this? I have no cooling problems or problems at all on 6s. I use the Nano-Tec 65-130c liops.
        What are your thoughts with the HK nano tech high discharge lipos?
        Thank you.
        twissted from speed. Lead, fallow or get out of the way. Copy cats in back of the buss!!!
        • twissted
          • 896
          #64
          Product Feature: 1-8SBB3.jpg
          Use for 1-8s Lipl/Li-ion/LiMn/Li-Fe
          Voltage detection pricision: 0.01V
          Unit voltage display range: 0.5V-4.5V
          Total voltage display range: 0.5V-36V
          1S test mode voltage range: 4-15V
          Low voltage alarm mode for 2-8S
          Alarm set value range: OFF-2.7V-3.8V
          When the voltage is below the set value,it will buzzer with red LED light,pre-set value 3.3V.
          Push key
          • larryrose11
            • Jun 2010
            • 768
            #65
            here is what I did to my T180 heat sink
            The original, featuring broken water connectors!!
            I milled most of the center out
            finished part
            assymbly
            finished heat sink
