Turnigy 180 cooling upgrade
  • properchopper
    rcgoatbuild@snotmail.com
    • 7708
    Originally posted by martin View Post
    When you remove & mod the cooling plate what do you use when you put the plate back on to the esc re heat sink compound. I can get the white paste heat sink compound, is this stuff suitable. Thanks Martin.
    That's what I used. Should work fine.
    • martin
      • 2881
      Thanks Tony, can i ask on the T180 when you use no lvc do you use a low voltage alarm or just keep an eye on run times. Thanks Martin.
      • properchopper
        • 7708
        Martin,
        All my boats are configured for sprint (or offshore). Averaging 2 1/2 to three minute runtimes, the race setups are geared towards leaving a safe amount in the batteries.
        I've gone high-tech timing my setups ( I really do use this !)
        • SirBudman32
          • Aug 2011
          • 701
          Just to let you guys know the heat trick works great for getting the brass nipples out of the ends. I used my mini torch and they came right out.
          Turnigy 180 (7).jpgTurnigy 180 (5).jpgTurnigy 180 (4).jpgTurnigy 180 (6).jpg
          Modified Jae21, Stock Jae21, Cheetah, Ul-1, Shock Wave 26 V2 (Rescue Boat).
          • teddyboy
            • Jan 2010
            • 559
            Tony, Where did you get the 90 degree fittings and are they 10/32? Also, do I owe you some parts from a UL-1?
            Thanks Ted
            Ted H. Wachter
            West Florida Model Boat Club
            East Texas RC Boaters
            • properchopper
              • 7708
              Thanks Ted
              Ted,
              These are what I've used : (toggle down; you'll see them) http://kintecracing.com/Water_Cooling_BQFJ.html
              I've also used these (larger i.d.) - Aeromarine or Insane Boats has them (Kintec's out of stock)- call to order : DSC03406.JPG
              both are 10/32
              Be VERY CAREFULL when removing the original barbs - they break off easy & then
              Put a drill bit snugly in the barb to keep it from collapsing , hit the joint with a torch, then CAREFULLY break it loose & unscrew.
              You were going to send me a UL-1 strut.
              • G-UNIT
                • 971
                jwt:
                Did you also drill through the sides to get the holes into the center section then seal up the outside holes?
                I can't tell in your pics, in photo #3 I see the hole on the inside but don't see any holes on the outside.
                just last night I took the plate off a bad t180a and was contemplating what I could do with it and then this morning here it is, wow what are the chances.
                • teddyboy
                  • Jan 2010
                  • 559
                  Tony, thanks for the response. I will be going back to Longview, Texas and I will round up the UL-1 strut(s) I promised you. I am still in Florida and haven't found time to take care of that business. I will take care of it 2nd week in August. Sorry and thanks for the information.
                  Ted
                  Ted H. Wachter
                  • teddyboy
                    • Jan 2010
                    • 559
                    Tony, my flight got cancelled, trip in two weeks to get those struts for you. The esc cooling mods are complete as per your instructions. Thanks again. Ted
                    Ted H. Wachter
                    • properchopper
                      • 7708
                      • viper1
                        • 219
                        And just when you think you've seen all variations....
                        Here's another one, most of it not new but for me the ideal combination.
                        I didn't want to make more holes than necessary, so I drilled 4 holes under an angle, like jwt did.
                        Next I made a divider or 'dam' from thin aluminium, JB-welded in to keep both sides separated and the water can not go ways it's not supposed to go. (Not likely, but possible if left out) This way I can still use it for dual, or single pickup.
                        To mount the covers securely, but not permanent, I wanted to use the nipples to hold the covers on.
                        For this I had to make new nipples with a small flange, as the original nipples are constant diameter.
                        I think the result looks "cool" ? (pun intended)
                        Wisdom is knowing how little we know
                        • viper1
                          • 219
                          Final Photo's :
                          • properchopper
                            • 7708
                            Nice Job Have a question ; what tubing did you use that makes nice 90 deg. bends without collapsing ?
                            • viper1
                              • 219
                              Thanks Proper,
                              That's just "painted on" using the photo before it.
                              But with the tygon fuel tubing I use for cooling, reality would not be that far of I guess. but it probably will naturally sit in a U-shape instead of 2- 90 deg. bends
                              • Megabiker98
                                • Jan 2013
                                • 253
                                This and the seaking esc is the same thing correct???
