That wet box looks like a good idea.
U-31 MILLER HIGH LIFE 8th Scale build thread
Started skinning the sponsons and non-trip. Decided to go with .06 styrene sheet because its light, durable and bends easy.~~~~~~~~`Mach 5 racing'~~~~~~~~~~~~
****2008/9 MMEU LSO, 2008 LSH CHAMP****
~~~~~~~70 MPH Club Member!~~~~~~~~~
Styrene is tricky to bond,`Marine GOOP' works very well. Be advised use in a well ventilated area. Stinks real bad...
https://www.amazon.com/Amazing-GOOP-...EQ1WFN1FHC4HGQ~~~~~~~~`Mach 5 racing'~~~~~~~~~~~~
More sponson skin(styrene) and ride pad(G10) bonding~~~~~~~~`Mach 5 racing'~~~~~~~~~~~~
Thanks Buddy!Originally posted by RandyatBBY View PostGreat build Ken.
Last of the sponson skins bonding. Careful balance of aero, fluid dynamics and contact patch went into the right & left sponson designs. Overlaps still need to trimmed and fine sanded.~~~~~~~~`Mach 5 racing'~~~~~~~~~~~~
THANKS!
More pics front canard wing structure, sponson floatation and through hull motor mount bases bonded in.~~~~~~~~`Mach 5 racing'~~~~~~~~~~~~
Finally G-10 top skins are bonded to sponsons. Used small wood screws to hold the edges down while overnight bonding. They will be removed, holes filled etc...Attached Files~~~~~~~~`Mach 5 racing'~~~~~~~~~~~~
Looks like you are fast approaching the down hill side of the build. Very nice work my friend!MODEL BOAT RACER
IMPBA President
IMPBA 19887L CD
NAMBA 1169
CF Ram Wing skin & Bonding deck joints
The deck is put together in sections for ease of assembly (and repair). CF Ram Wing exterior skin bonding & deck joint are composite so you wont read joints if the boat gets really soaked.Last edited by K.R.Joye; 01-02-2019, 11:37 AM.~~~~~~~~`Mach 5 racing'~~~~~~~~~~~~
Bonding main Deck panels
Similar to sponson deck panels, these are glued and temporarily screwed.~~~~~~~~`Mach 5 racing'~~~~~~~~~~~~
One of the most durable boats I own!
