U-31 MILLER HIGH LIFE 8th Scale build thread
  • K.R.Joye
    • Feb 2010
    • 1423
    Gents, I'm making a lot of progress on my winter project U-31 `Miller High Life' Unlimited Hydroplane. Based on the Lucero designed Circus Circus platform, the`Miller High Life' was campaigned briefly on the 1988 Unlimited circuit. The scaled down 43" hull will legally meet all overall dimensional info provided on the NAMBA MHR#8700.
    I inherited this project from a good friend as a plywood framed skeleton from Newton #146 plans. Most of the wood frames were disguarded after being used for patterns in favor of stronger G10 Epoxy sheet composite. CF angle will also be used for structural support, plywood Transom & Sponson bulkheads are G10 skinned. West Systems #610 2-part epoxy is used for bonding and Z-Poxy for sealing a bonding any wood to wood component. The center section of the hull has been offset from Port to Starboard for FE clockwise racing. Epoxy Glass Canopy, Cockpit and rear Wing Set(on order) are RC Boat Company pieces.
    Power will be provided by IMPBA legal 1527 1.5y or Plettenberg HP370 BM A1-S on 10s1p lipo. Offset 3/16" cable driveline and hardware will consist of a combination of Zipp Kit(turnfin) and Speed Master(rudder,strut) components. Same hardware and driveline setup is used on my U-1 Atlas Van Lines.
    Here's some pics so far showing rear afterplane tub construction. Everything is swiss-cheesed to save weight. Working my way forward to start soon on front sponson & canard spar structure.
    ~~~~~~~~`Mach 5 racing'~~~~~~~~~~~~
    ****2008/9 MMEU LSO, 2008 LSH CHAMP****
    ~~~~~~~70 MPH Club Member!~~~~~~~~~
  • K.R.Joye
    • Feb 2010
    • 1423
    Cockpit/Canopy
    RC Boat Company canopy to be integrated into the hull.
    • bob horowitz
      • Apr 2016
      • 259
      Ken,
      Nice job. Makes me itch like crazy just thinking about cutting all that G-10. Great idea though.
      Bob
      • emspjay
        • Sep 2017
        • 411
        Great build! That is very cool! Can't wait to see it finished!
          Very nice. The canopy will really set it off.
          • K.R.Joye
            • Feb 2010
            • 1423
            Picklefork Structure
            Worked on locking down the front sponson structure. The (2) CF angles are tied together with hardwood beams bonded to inside sponson walls to eliminate pickle fork twist. The forward CF angle will be part of the nose canard wing structure while the rearward CF angle will support the sponson transoms tying them in to the tub.
            Sponson bulkheads and stringers next...
            • revoltrunner
              • May 2014
              • 646
              I bought these decals back in the 80s
              and never used them.
              just realized these are for the Miller American
              not the Miller High Life.
              • K.R.Joye
                • Feb 2010
                • 1423
                Sponson structure
                Bonding the Sponson transom & bulkheads along with stringers
                • Doug Smock
                  • 5359
                  Looking good Ken!
                  MODEL BOAT RACER
                  IMPBA President
                  IMPBA 19887L CD
                  NAMBA 1169
                  • K.R.Joye
                    • Feb 2010
                    • 1423
                    Thanks for the nice comments guys. This nasty Mi. winter is providing me with lots of shop time.
                    Hopefully if all goes well i'll have some better competition for you Doug!
                    • 785boats
                      Wet Track Racing
                      • 3423
                      Coming along very nicely.
                      I've never seen a hdro built up out of G10 epoxy sheet before.
                      Very interesting.
                      • K.R.Joye
                        • Feb 2010
                        • 1423
                        Very interesting.
                        Thanks I've been following your U-3 build also your doing a great job! I've built plywood kits too, just to hard to repair when bad things happen.
                        • K.R.Joye
                          • Feb 2010
                          • 1423
                          Working on the sponson bottom structures today. The West Systems 610 2-part epoxy i use on the G-10 takes overnight to dry so I try to setup something up for bonding as frequently as possible.
                          • K.R.Joye
                            • Feb 2010
                            • 1423
                            CF angle air trap vents are in!
                            • K.R.Joye
                              • Feb 2010
                              • 1423
                              Bonding sponson bottom stringers, note right pic show CF flat plane ride pad forms
