ML Boatworks RSX380 , The big brother to the RSX310, 38", 6s lipo- Q FE Rigger!
  • cybercrxt
    • 2926
    Well, the 6s version design is now finished. It is the RSX380, 38" FE rigger. Shown in the plans here are a 40x82 motor with water cooler, and a 6s 5000mah pack, which you can see, fits fine. The tub is 4-1/4" wide, so there is plenty of room in this hull. Like the RSX240 design I just finished, I need to do the cowling plug and mold for this hull, but the wood kit, is done. More on this soon! Mike
  • Peter A
    • 1622
    Hi Mike
    Will you be able to supply these with turn fins also? Keen as mustard for one so put me down for one when they are ready.
    Cheers
    Peter.
    • cybercrxt
      • 2926
      Peter, yes, that should not be an issue having fins for this, or the 24" version.
      • romspacenut
        • Aug 2016
        • 4
        Dangit Mike,
        I'm building the 171 and 172. Now I gotta get this too. Nice works buddy!
        • cybercrxt
          • 2926
          The framing for the RSX240 and RSX380 cowling plugs arrived. So now, I will be starting on them. The 240 is easy as I can cut down the RSX310 cowling pictured, but the RSX380 will need a larger cowling, so I will have to make one up from scratch.
          • Tomcandersen
            • 91
            Any news on this one Mike?
            If not today, maybe to morrow..
            HPR C5009 twin TP power 4082 2390kv 95mph, Sprit Cat 36 singel Proteus 65mph, Baby SV43 TP power 5850 920kv 12s 70mph
            • cybercrxt
              • 2926
              Just replied to you on IW. I am going to get to work on this cowling plug probably next week. Just gotta finish up some of these other plugs I had started first! Thanks, Mike
              • cybercrxt
                • 2926
                Finally started on the RSX380 cowling plug last night. I will get it finished in a couple weeks. This will finish out the 240, 310, and 380 hulls, and eventually, I am going to do a gas rigger. Mike
                • T.S.Davis
                  • 6266
                  The fin Kevin makes for the 38 is likely the same one I run on my Q sport. Awesome piece of engineering and craftsmanship.
                  Noisy person
                  • cybercrxt
                    • 2926
                    Yep, it will be Kevins 40 fin I offer with this. He definately does excellent work! Im impressed with the quality, and turn around time!
                    • T.S.Davis
                      • 6266
                      You can hang a lot of G's on that material too.
                      Noisy person
                      • Peter A
                        • 1622
                        Hi Mike
                        How are these coming along. Any idea when the kits will be ready?
                        Peter.
                        • cybercrxt
                          • 2926
                          Hey Peter, The kit itself is fully designed, and has been cut. I just need to finish up this plug. I have an order for one of these kits, so I need to get the cowling done. I am hoping shortly. Always so busy, but this is on the list! Mike
                          • cybercrxt
                            • 2926
                            I finally sat down and forced myself to find time for this. This is the RSX380 cowling plug, next to the RSX240 cowling. So far so good. I plan on having this finished by next week, and a mold made.
                            • cybercrxt
                              • 2926
                              Cowling plug is all but done. Just need to wet sand it, buff, and make the mold. Once that is done, this kit will be on sale on the website. Mike
