Looking to buy EKOS
  • Bug777
    • Jun 2010
    • 103
    #91
    Port esc would not reverse. Starboard side will. Plugged motor from port side into starboard esc & it works properly. Plugged starboard engine into port esc & still no reverse. Removed "Y"harness & tried each esc individually. Same result. Sent first esc back to Venom. They said it was fine. I got it back & still the same issue. Venom then sent a new esc to the lhs. We tried it & still the same issues. We tried a different receiver but no difference.
    Venom now want the transmitter, receiver & both esc's sent down so that they can see what's going on.
    • VIKOS
      • Jan 2010
      • 204
      #92
      see she turns when you reverse lol whats the problem...just learn to drive you will never use reverse unless your in a pond that 20'X20' lol in that case get a mini...
      • Bug777
        • Jun 2010
        • 103
        #93
        I only want reverse so that it can get on & off it's trailer.
        • VIKOS
          • Jan 2010
          • 204
          #94
          lol wow really trying to be realistic here huh? lol god speed then..
          • Bug777
            • Jun 2010
            • 103
            #95
            I got the boat backyesterday from Venom. They fixed the reverse problem which was great. It was to do with the sub trim. When i sent the controller down the throttle sub trim was at -18, when i got it back it is now -12.
            • Bug777
              • Jun 2010
              • 103
              #96
              The boat is going better now. Here are some pics. Once i get my new batts in a couple of weeks i will post another video.
              • JPriami
                N4FOX
                • 1711
                #97
                cool pics
                • Bug777
                  • Jun 2010
                  • 103
                  #98
                  Will these plugs handle the current?http://www.hobbycity.com/hobbyking/s...10_pairs_(20pc)
                  I will be placeing my order for the batteries in the next couple of days & want to ge the connectors at the same time.
                  • forescott
                    Hopelessly Addicted to RC
                    • 3009
                    #99
                    Yup, 4mm is fine. Stock bullets from motor to esc are 3.5mm.
                    • forescott
                      • 3009
                      #100
                      Depending on what type of batteries you purchase you might need larger bullets. Some batteries have 10 or even 8 gauge wire, which may be too big for those 4mm bullets. Check the battery specs before you get em.
                      • Bug777
                        • Jun 2010
                        • 103
                        #101
                        Thanks forescott for your help. I have ordered these today.
                        Now i just have to wait a couple of weeks for it to get here. I will post pics & thoughts once they arrive.
                        • forescott
                          • 3009
                          #102
                          Nice, I have those same packs as well.
                          • Bug777
                            • Jun 2010
                            • 103
                            #103
                            The new batts arrived today. Now the long soldering night infront of me converting all of the connectors over includine making charging leads.
                            • Bug777
                              • Jun 2010
                              • 103
                              #104
                              I went to fit the packs today & it looks like i have to modify the battery box's a bit to get the cables out otherwise the batts don't sit flat on the floor.
                              • JPriami
                                N4FOX
                                • 1711
                                #105
                                I think we spend more time working on the boats than running them lol.
