Looking to buy EKOS
  • forescott
    Hopelessly Addicted to RC
    • 2686
    #61
    Also, some of the off-brand cheaper lipos are only rated at around 15c, which is inadequate.
    • scubasteve95
      • Apr 2010
      • 239
      #62
      Originally posted by forescott View Post
      True scuba, but if the mah is too low then the batteries wont put out enough amps that the motors require to reach their maximum potential. I wouldnt dip below 3000mah on any brushless setup.
      i started my boat on 3s-2200mah.
      didn't jump up to the 4s-5000mah for about a month,
      i thought i ran great.but i took apart the whole boat
      and messed with the whole set-up
      before i ran.
      • scubasteve95
        • Apr 2010
        • 239
        #63
        what c are yours?
        my 4s-5000 are only 20-40
        • VIKOS
          • Jan 2010
          • 204
          #64
          Originally posted by LarrysDrifter View Post
          Im with forescott on the wire drives.They are awesome.Be sure to use collets and not the set screw type couplers.
          I don't know everyones complaining about the collet issues more than the set screw issues,maybe because no one is running them but with the 4 set screws on the flex shafts and blue loctite Ihave no issues at all..like I said flex shaft twisted snapped clean of and the screws where still tight as nails...
          • forescott
            • 2686
            #65
            Originally posted by scubasteve95 View Post
            what c are yours?
            I'm using turnigy 3300 4s 30-40c and 3600 4s 30-40c
            • forescott
              • 2686
              #66
              I think they both work great. I have Jeffs couplers for the flex cables too. I just like the collet style better so far.
              • VIKOS
                • Jan 2010
                • 204
                #67
                right right. Gona try the couplers for wire drive that he sells some time in the near future while parts are on order..I'm just looking for 50mph from this boat and she'll be fun..that is on 5S of course lol
                • Bug777
                  • Jun 2010
                  • 98
                  #68
                  These are the batteries that i am looking to purchase. Are they any good?
                  http://www.hobbyking.com/hobbyking/s...dProduct=10097
                  • forescott
                    • 2686
                    #69
                    Those are perfect. A set of 30c packs are actually more than enough if they have em in stock you can save a couple of bucks!
                    • forescott
                      • 2686
                      #70
                      I have the exact same packs and they are awesome.
                      • Bug777
                        • Jun 2010
                        • 98
                        #71
                        Thanks. I will be ordering them with in the next couple of weeks.
                        • forescott
                          • 2686
                          #72
                          You might want to consider ordering a few sets of connectors. The ones that come with the lipos wont match up to the stockers anyway. Hobbyking sells ec-5 connectors for only a couple of bucks a set. They are a good upgrade for you're ekos.
                          • Bug777
                            • Jun 2010
                            • 98
                            #73
                            Thanks. I use deans style plugs on all of my stuff anyway. I got a phone call from Venom about the ESC i sent them. They reckon it works fine. I will see when they send it back if it works, other wise i think the motor is playing up. They are also sending up a programming lead for the esc's as well.
                            • LarrysDrifter
                              Big Booty Daddy
                              • 3278
                              #74
                              You will be much better off using bullets.Save the deans for your cars n trucks.Or throw them away.I used deans on my boats,and while they are nice,arent meant for the amps FE has.Bullets are probably on of the best up-grades you can do for your boat.
                                • 9479
                                #75
                                I have the 30c versions and they work great!
                                and I think they are much cheaper
