OSE Strut for Spartan - Dual lead teflon bearings and oil fitting.
  • Steven Vaccaro
    Administrator
    • 8934
    OSE Strut for Spartan - Dual lead teflon bearings and oil fitting. For use with 3/16" prop shafts. Much smoother than the stock hard metal bushing. Bushings are press fit in.
    Steven Vaccaro
  • dag-nabit
    • Feb 2011
    • 775
    Nice,
    I'm a bit unclear on the oil fitting. Is the idea to connect a small oil reservoir to the fitting using tubing?
    Kevin
    • Steven Vaccaro
      Administrator
      • 8934
      Sure, or just a simple place to get the oil to both bushings without having to remove the shaft/cable.
      Steven Vaccaro
      • johnl6676
        Anything R/C
        • 363
        Steve what is the part number I don't see it listed anywhere. Is it available from you?
        JohnL6676
        Everything RC Retired don't know how I ever found time to work.
        • Steven Vaccaro
          Administrator
          • 8934
          Its not on the site yet. I'm going to get it and a couple of other new things on by Friday.
          Steven Vaccaro
          • johnl6676
            Anything R/C
            • 363
            Ok thanks.
            JohnL6676
            • jetnfast
              • Apr 2013
              • 162
              Very nice, would like to order one of these to have on hand as a replacement for my stock strut which has over 100 runs on it. Will this fit jeff wholts .187 cable for the Spartan? I am already running one of those with the stock strut and seem to think it might not work with this one since his cable is made to fit the stock strut, I think it has a 5mm shaft machined to a 3/16''. I could be wrong though...
              • Steven Vaccaro
                Administrator
                • 8934
                No this will not fit. Its made to fit the more popular .187(3/16") prop shafts.
                Steven Vaccaro
                • Spartanator
                  • 1060
                  I just got mine and I must say I am impressed with the product! It's way stiffer and thicker than the original .150 stock cable. Can't wait to use it!
                  • Spartan
                    • Feb 2012
                    • 60
                    If I'm not mistaken this will work with the .187 cable correct? Nvm answered above.
                    In Steve's post it says 187 I believe he means .150 correct
                    • Steven Vaccaro
                      Administrator
                      • 8934
                      Spartanator is referring to the entire system I sell for it. .187 flex cable, coupler and strut.
                      http://www.offshoreelectrics.com/pro...rod=ose-C-1405
                      Just to clarify .187 is the propeller shaft size. That size doesn't have anything to do with the flex cable size. You can use whatever flex size that your boat needs. Upgrading the flex cable to .187 from the stock .150 will also increase the strength of the system.
                      Steven Vaccaro
                      • Spartan
                        • Feb 2012
                        • 60
                        So then the strut would fit the .187 cable?
                        • Steven Vaccaro
                          Administrator
                          • 8934
                          yes
                          Steven Vaccaro
                          • Spartan
                            • Feb 2012
                            • 60
                            yes
                            Well then off to the store... I'll pm u if I can't find it....
                            • Spartan
                              • Feb 2012
                              • 60
                              yes
                              Steve, do bearings go on each end or the flex cable just goes through n floats on those bushings?
