What is the deal 43MPH still?!?!?!?!?
  • MAMBA2200
    I need a scooby snack
    • 1196
    #91
    i agree i would pay more(the little more) for better electronics
    • traeside
      • Aug 2012
      • 190
      #92
      Okay I will agree that this hull has issues but tossing another $27 for the rudder is not going to make a difference at this point and unless you smoke something you still have the option of putting it back to stock buy a good hull and put all the good stuff in that. but until I can find a good deal on a hull I will keep beating my dead horse. I got her out yesterday with the new rudder. I was running with the stock electronics and a Prather 215. The boat ran much more stable but still ran totally wet. I cannot get it out of the water. I have the batteries all the back and I even kicked the strut up 1 and same thing. It is also laying on its side like crazy. At speed it the right side of the V is level in the water. I rut the left side tabs to 0 and gave the right side +2 It did not help. By the end of the second run the ESC was up to 140. I got it home and I put the SK 180 and the 4090 back in. I will put the X645 tonight and see if I can get her out this week.
      • MAMBA2200
        • 1196
        #93
        have you checked to see if your hull has a hook on the bottom lay a straight edge and make sure its level and theres not a hook at the transom pulling the front down
        • traeside
          • Aug 2012
          • 190
          #94
          come to think about it, i think it does i will check tonight. good call
            • 4297
            #95
            Hey,
            Do you still have your trim tabs set like this and stringer or strut ?
            If so,
            This should be a easier way for you, I do it at the pond all the time.
            I take a ruler or straight edge and put it against the bottom of the hull vee at stern 6" or so over lapping the hull,
            And the rest under the stinger or strut end and check the distance between them for 3/16",
            Then tighten the bolts.
            Also move the trim tabs up about 1/4" at the back center of tabs,
            Just move the adjusting bolts all the way up and bend the tabs up to make it easier.
            I take a ruler or straight edge and put it against the bottom of the hull stern 6" or so over lapping and the rest under the trim tab,
            And check the distance of each one.
            Than move the bolts back down to zero it in on 1/4" and then lock them.
            Get some video of it running with these setting first on glass if possible and close to shore with long saw runs.
            Than if it start to plane to much bring the trim tabs down a little at a time to stop it from hopping at high speeds.
            If you adjust it, Do one thing at a time and test again,
            To say on track of it.
            Originally posted by traeside View Post
            Okay all mounted up.
            [ATTACH=CONFIG]87264[/ATTACH]
            • traeside
              • Aug 2012
              • 190
              #96
              From that shot the stinger is up port side up starboard down. i will get it on the table tonight and let you know how far off i am and i will get her to your specs
              thanks
              • Niky
                • 61
                #97
                Hi Guys,
                someone can tell me please if there is on OSE Store the upgraded proppeler flex cable and rudder for the Spartan.
                I'm planing to order (have to), the ESC and motor allready prepared by guys at OSE for 6s for the Spartan and I'd order these other two things
                to improve the problems with collet coupler and cooling.
                Thabks all, salute Niky.
                • traeside
                  • Aug 2012
                  • 190
                  #98
                  I posted earlier with a good setup. You can also go to the top and click onOSE parts for a great selection under spartan upgrades
                  • traeside
                    • Aug 2012
                    • 190
                    #99
                    Ding! Ding! Ding! MAMBA22000 lets tell you what you have won, you have one a factory certified previously owned Spartan hull. Slightly deformed. LOL I am guessing that this is enough to do it.
                    • traeside
                      • Aug 2012
                      • 190
                      #100
                      NiKy,
                      can you put a straight edge on yours and post a picture for me?
                      • MAMBA2200
                        • 1196
                        #101
                        yes that is enough it dont take much to hook and pull the nose down that be you problem the best thing i can tell you is pull the battery trays and lay thin plywood in the bottom and epoxy it in to make the bottom ridgid and straight that is one of the things i did to mine to make her handle well
                        • traeside
                          • Aug 2012
                          • 190
                          #102
                          or i can pull everything and put a new hull under it. LOL any sugestions? is the Mean Machine 18 Hull from aeromarine the same as the mean machine sold here?
                          • MAMBA2200
                            • 1196
                            #103
                            yes that is true a glass hull would be better
                            • traeside
                              • Aug 2012
                              • 190
                              #104
                              but is the one from Aeromarine the same or is made up diferend for a nitro
                              • MAMBA2200
                                • 1196
                                #105
                                i dont know about that maybe someone else will chime in on that
