What is the deal 43MPH still?!?!?!?!?
  • traeside
    • Aug 2012
    • 198
    Okay so I was running 41 on the stock setup with 6S, 3 tabs at 0 right inner -1 strut at +,1 batteries all the way back. Now I have the SeaKing 180, Leopard 4092 1480K and Prather 220. Still could not break 43. I think the hobby king 3S 5000 45C are not holding up. I am getting the low voltage cutting out under hard cornering. I had it set at 3 volt. Now at 2.8 but not tested. I am running on flat to very mild water. All temps at 80-90 degrees. I am going to try the Octura 642 and see what that gets me. With 80% efficiency and 25% slip the 220 should be 48MPH. it looks like it is running wet and start chine walking almost every time I get to WOT.
    So unless anyone has a better suggestion I will order some Gen Aces 5300. And just keep going up on the props tell it gets hot.
  • Make-a-Wake
    FE Rules!
    • 6057
    Adjust your COG before buying more stuff. If its running wet, its probably due to the greater lift created by the 1.5 pitch Prather 220. Play with the strut/stinger angle and COG.
    • traeside
      • Aug 2012
      • 198
      I will check where I am at but the only thing I can take out or move back is the gps. I tried +2 on the strut and I was slower
      I have the 642 i just have to work it still
      • martin
        • 2881
        A good starting point for cg is 30% of the hulls length in from the transome.
        • traeside
          • Aug 2012
          • 198
          If I had to guess I would think I am further back then that with extra trim tabs 5000's all the way back. But maybe the 4092 is heavier then I think
          • martin
            • 2881
            You may find that at 2.8v on the lvc it works better, id even try no lvc to see if that makes any diff if the 2.8v dosnt work better but you must watch run times with no lvc. Re motor weight the 4092 isnt much heavier than the 4082 motors that work very well in the Spartan & are a popular upgrade, something deff wrong on your boat as the 4082 are good for around 60mph.
            • traeside
              • Aug 2012
              • 198
              see thats why I am thinking that my batteries are not keeping up. i am worried about going to no LVC but that is a good idea, during the testing i am only going 2 min, then brining it in for temp check and battery check. FYI the bateries were still showing 60% after the second run were i had sevral cut outs.
              • Make-a-Wake
                FE Rules!
                • 6057
                Balance the boat on something to find the COG and divide the length from transom by the overall length, the best cog is around 27-30%.
                A boat is not supposed to be "setup" taking a GPS into consideration, its not one of the needed components. Do you want a good running boat or one you can measure the speed of and runs badly?
                • traeside
                  • Aug 2012
                  • 198
                  I want it all!!! LOL yeah i will check the CG as soon as i get home tonight, with and without the GPS. here is a stupid question is 0 on the tabs when the end of the tab touches a ruler running along the bottom of the hull?
                    If it is chime walking then it is not running wet. The temps also indicate low amp draw. Something else is happening.
                    Try a different ESC, perhaps yours is not getting full throttle. It is possibly the packs, I'd borrow some to test before I bought all new equipment.
                    • dana
                      • Mar 2010
                      • 3660
                      What radio?
                      • traeside
                        • Aug 2012
                        • 198
                        i wish i could post the videos, upon further review at WOT pass 10 feet from me it just looks totally level but there is just not much of it in the water. I was looking for the nose to be higher again I know my real boat knowledge doesn’t always apply here. Not sure about the ESC not seeing full throttle. I set it up and I am able to get into program mode okay. also right or not telemetry from the radio showed 30,000 RPM on the last pass. I have to get the radar gun out there.
                        okay I will check CG get it to around 30% I need a set of batteries anyway so I will get them. I have seen someone running with 2 6S 5000 (which I have in stock) in parallel but that seems like a lot of weight. the good news is if I am still cool and at 30% COG I might have some room to put the tabs down and actually get some of the chine walk out of it. thanks for all the help guys
                        • traeside
                          • Aug 2012
                          • 198
                          Spektrum DX2S
                          • traeside
                            • Aug 2012
                            • 198
                            the HK packs have done this to me before on a hot funjet. it would not run up to speed with them then drop in a hyperion on off it went.
                            • traeside
                              • Aug 2012
                              • 198
                              Okay so with the packs all the way back I am at 24% and 25% with the gps in the front I marked 11 inches from the transom (30.5%) and started shifting the packs forward. They are now all the way at the front! So if I was this far off how did I not have a blowover or why was the bow at least high? So if I run like this I would think I would be more stable but will it be faster? The opposite would be normal
