Castle 1717 Direct FIT?
  • Shaun78
    • Feb 2011
    • 419
    Is it a good choice or TOO much power? Will it fit with no mods?
    Genesis (Bosncali Geico Beater) Leopard 4082 1500KV
    (63.7 MPH) Traxxas Spartan (same setup)
  • LarrysDrifter
    Big Booty Daddy
    • 3416
    Too much.
      • 9481
      the CC1717 does fit, a little snug with the water jacket
      almost the same kv as the CC1520 1600kv
      • wilsta67
        • Feb 2011
        • 203
        im fairly sure the shaft will need to be shortened and the collet will need to be drilled out to fit the 6mm shaft the stock motor has a 5mm shaft.
        so not a direct fit.
        • LarrysDrifter
          Big Booty Daddy
          • 3416
          The 1717 has a 5mm shaft.
          • Diesel6401
            Memento Vivere
            • 4391
            The 1580kv car version has 5mm shaft
            The 1500kv air version has 6mm shaft
            - Diesel's Youtube
            - Diesel's Fleet
              • 9481
              YES, and I have two of the air motors and thinking I may try them in a twin something
              • Diesel6401
                Memento Vivere
                • 4391
                Here's something I have been working on. I wanted to use the car verison with a waterjacket on my vanquish hull but quickly found out jackets are very hard to find right now, so I decided to air cool a 1717 car verison.
                I removed the rear endbell and drilled cooling holes into the endbell, i replaced the stock CC endbell screws with leopard ones (i like them better, easier to install and remove) I then drilled holes in the front cap of the motor. I made a gasket around the endbell and installed a 12v brushless 40x40x20 computer fan that runs off of a 3s 2200 3c lipo. I attached the fan to the motor and the fan will draw heat away from the motor. I then modded the stock motor mount and allowed a gap between the motor and the motor mount to allow air to be allowed to be pulled threw the motor. I will be using a sr3300t rx with telemetry so I can get live motor temps on my dx3s radio. Haven't tried it yet but hell it's worth a try. If it doesn't work I slap a different motor into it and consider it a $70 learning lesson. So with that being said, a twin 1717 air cooled would be sick! JMO
                Here's the thread on everything more in detail: http://www.rcgroups.com/forums/showt...1405388&page=7
                - Diesel's Youtube
                - Diesel's Fleet
                • Diesel6401
                  Memento Vivere
                  • 4391
                  Final pic:
                  - Diesel's Youtube
                  - Diesel's Fleet
                  • CHUD
                    • 554
                    Final pic:
                    NICE// D //NICE
                      • 9481
                      Very cool idea D!
                      I'm thinking of trying water injection on a outboard setup
                      let the can fill with a constant flow of cool water
                      • wilsta67
                        • Feb 2011
                        • 203
                        Originally posted by LarrysDrifter View Post
                        Too much.
                        NEVER TO MUCH
                          • 9481
                          NEVER TO MUCH
                          should be just about perfect!
                          • wilsta67
                            • Feb 2011
                            • 203
                            he never said which one he was asking about i assumed it was the aircraft as you cant buy the car one anymore, and they have the aircraft motors on sale.
                            • Make-a-Wake
                              FE Rules!
                              • 6057
                              Load up on the 1580kv car version here.............
