Spartan, tear it down to build it up
    • 9481
    #136
    Originally posted by GeoVW72 View Post
    Yea, Yea, that is the right way to do it, I guess I'm just lazy.
    not sure what you could do with the transom though, unless you do dag-nabit's mod to a t
    I was thinking of using some 1/4" door edge foam..
    • Shaun78
      • Feb 2011
      • 419
      #137
      what setup did u run today to get rid of chine? I tried mine 4.5MM strut and batteries all the way back and tabs all up. little chop, chine walk YES.....Did run fast though but i couldnt hold WOT due to chine
      Genesis (Bosncali Geico Beater) Leopard 4082 1500KV
      (63.7 MPH) Traxxas Spartan (same setup)
      • GeoVW72
        • Jun 2010
        • 258
        #138
        Move the batteries to mid-forward, take a little bit out of the strut angle .5-1mm.
        Loosen the strut mounts and shift the strut up and to the right then re-tighten them
        Team Boca Bearings
        S&G Design
          • 9481
          #139
          get the hull a little wet
          • shctexas
            • Jan 2011
            • 158
            #140
            Brushless, thats what I used, adhesive-backed 1/4 " foam. It comes in a roll from Home Depot. I inserted it in the groove the hatch edge fits in. Also across the back of the deck, immediately in front of the transom but behind the drain hole. Its snug pinning the lid down but to me thats not a bad thing....yet. As an added measure I put a small strip in each of the lid "overhangs" (the ones Dag-Nabit removed). It works well.
            • Shaun78
              • Feb 2011
              • 419
              #141
              With my current setup I moved the batteries midforward a little...same 4.5mm strut which is slightly positive and wobble was gone but speeds were 42 but my packs were almost ready to cutoff. I can run 42-43 with no chine walk but thats not fast enough. 44 and up u get chine. maybe my spartan is maxed out and time to upgrade. I think low 50's with no chine i would be happy. maybe a T180 and Leopard 1450-1600kv is in my near future
              • Shaun78
                • Feb 2011
                • 419
                #142
                Will I be Ok if i use the traxxas high current connectors with an upgraded setup? I like to keep all my bats the same and I have some 2S that i would like to try when its upgraded but i also use them on my slash so I would like to keep traxxas connectors
                • dag-nabit
                  • Feb 2011
                  • 775
                  #143
                  The Traxxas connectors are good connectors, you will be fine with them IMO.
                  I upgraded to EC5 connectors, but only to be standardized between all my boats, not because I thought there would be issues with the Traxxas connectors.
                  Kevin
                  • Shaun78
                    • Feb 2011
                    • 419
                    #144
                    Good run today, very windy some a little chop which turned out better. 48.0 MPH on stock setup (must have been down wind though) 4.5MM strut, Rt side tab down a little, batteries in the middle, GPS up front. 48mph
                      • 9481
                      #145
                      Chop can be your friend
                      • GeoVW72
                        • Jun 2010
                        • 258
                        #146
                        ambient 48*f
                        Run#1 2x 2s P225
                        esc: 73* motor: 96*
                        Max amp: 95 speed: 39 mph
                        YT vid
                        Run#2 2x 3s
                        esc: 75* motor: 103*
                        amp: 87 speed: 42
                        YT vid 1
                        YT vid 2
                        Run#3 2x 3s
                        esc: 75* motor: 107*
                        amp: 91 speed 42
                        YT vid
                        So not blazeingly fast today.
                        I had a P225, prop did work well on 4s though
                        Maybe they should have had one on it out of the box, but I think that the power required is more that the stock NiMh can provide.
                        packs were pushed to the rear, so that is the cause of the slight chine walking.
                        Run#2 rudder needs to be square to run/cool right. Not sure why I get a dry lube squeak on the first 6s run, maybe it's the collet
                        I have setup tweaking to do, other tweaks are proving themselves quite useful though
                        Team Boca Bearings
                        S&G Design
                          • 9481
                          #147
                          Thanks George for putting on the bigger prop while running 4s!
                          so maybe to some running 4s2p with a bigger prop could be a nice way to go with this boat?
                          10,000mah of runtimes and fair speeds
                          • GeoVW72
                            • Jun 2010
                            • 258
                            #148
                            NP BL55 happy to take any suggestions, that setup sounds pretty good. The boat didn't have the same get up and howl attitude it has on 6s and it did chew through the 5200mah pack faster than before, but any setup that doesn't burn the thing up is good in my book
                            Tore some things apart today
                            motor really stinks now
                            rotor epoxy browned a little bit and the back end of the shaft has a shine to it.
                            So had to bust out a tweak that I think should have been factory:
                            I'm hopeful a Thrust bearing can take a good load off the motor. re-lubed everything.
                            Also found some damage I missed from the stuffing tube heat
                            melted the coating off the temp sensor wire.
                            More data tomorrow
                            Team Boca Bearings
                            S&G Design
                              • 9481
                              #149
                              How about trying 5s on this sucker?
                              • Shaun78
                                • Feb 2011
                                • 419
                                #150
                                what the rotor supposed to look like? Geo IM me an email address and ill send you rotor photo and tell me what you think?
