Thermal Issues with the New Traxxas Spartan
  • millzee
    Ozzie Bloke
    • Nov 2010
    • 1097
    #121
    Hey, any word on the Motley Crew ETA?
    "Gimmy Toyz for FUN"
    • pyroM!KE
      • 379
      #122
      No kidding..I just got a MG, But i see a MC in my very near future or whenever they come out..
        • 9481
        #123
        Bring it!
        • JPriami
          N4FOX
          • 1711
          #124
          Just wanted to post my experience today with the Traxxas Spartan. It was really the first time I have gotten to run it. Let me state the only things I have modified on my boat is the rudder itself. I opened up the inlet hole and I opened up the outlet nipple on the end of the rudder. And I changed out the stock TRX (are they rated at 30 amps?) connectors to 4mm gold bullets rated at 93A. Also sharpened the rudder and turn fins.
          It was about 40 degrees outside here in TN & raining a little. I used the stock NiMH packs first. I had no issues with heat on the motor or ESC. They were cold.
          My next test was with 2 Hyperion G3 EX 45C 3S 5000mAh packs. I ran a few laps 1-1.5mins and checked temps. it was cold. Then went and ran the boat for about 7mins. No problems. I checked the temps. The motor and ESC were still cool. I drove the boat like I always drive. Just sport driving having fun. I made lots of WOT straight runs for 4 seconds or so then slow and turn. But I never spend most of my time at WOT doing pass after pass after pass till the batteries are drained. I wonder if thats what some are doing not knowing any better?
          Later today I went back and GPS the boat it was about low mid 40's. I also ran it hard for about 2 mins with lots of WOT running trying to get the temp up. then brought it in and immediately shot a temp reading. it was 81 degrees F.
          I know I can get more speed out of the boat. i just need to adjust battery placement and adjust the strut angle and get a little more of the hull out of the water. 50mph isnt a far stretch on a good day.
          Oh and I guess I should mention after modding the rudder I think the higher flow of water is posing a problem for the silicon water jacket on the motor. Because at lower speeds I see a steady stream of water coming out of the outlet on the side. when I am going 3/4 to full throttle I dont see it much at all. but there is a bunch of water inside the hull (a cup or more). I suspect the motor jacket is leaking when i go fast. Im not 100% sure but its a theory. but water was sprayed all on the underside of the canopy. I did set the boat in the tub for a half hour to check for leaks before hand and just a little (1/2 teaspoon) came in around the hole going out of the transom for the stuffing tube.
            • 9481
            #125
            the water spray you see i guess is from the prop shaft not the cooling jacket
            and whey you run full speed the water stream is harder to see because the boat is going 40+mph and is no longer a stream but broken up by the 40mph wind
            • JPriami
              N4FOX
              • 1711
              #126
              water spray from the prop shaft inside the boat? really? interesting
              • Doug Smock
                • 5359
                #127
                I doubt a cup or more.
                If you want to find out for sure, fill and pressurize the water system with a syringe.
                My guess is the jacket is leaking when you approach 50 just like the silicone jackets do.
                Doug
                MODEL BOAT RACER
                IMPBA President
                IMPBA 19887L CD
                NAMBA 1169
                • JPriami
                  N4FOX
                  • 1711
                  #128
                  you could be right maybe not more than a cup meaning a measuring cup or .25 qrt. but I bet it wasnt far from it after running for that 7 mins. it was shocking.
                  damn that syringe idea is good. thanks. ive been trying to fig out a way to pressurize it. I was going to use my fuel pump to my planes or something.
                  • Doug Smock
                    • 5359
                    #129
                    No sir, I meant I doubt that much water came in through the drive line. Sorry.
                    You'll find the leak with a syringe if it's in the cooling system.
                    Good luck,
                    Doug
                    MODEL BOAT RACER
                    IMPBA President
                    IMPBA 19887L CD
                    NAMBA 1169
                      • 9481
                      #130
                      just blow throught the line off the rudder and you will find the leak
                        • 9481
                        #131
                        Originally posted by LarrysDrifter View Post
                        All I can say is,wow.The whole Traxxas forum deleting posts thing really bites me wrong.I have had zero intentions on getting a Spartan,but to advertise the thing the way they do-give me a break.From what Ive been reading on the boat,they are going to drive alot of their customers away.It makes me feel ashamed to own a 2.5 T Maxx that Ive had for the past 10 years-and I dont even play with it.
                        And again Traxxas mods (just two minutes ago) do more deleting to make is look like traxxas customer support knows much more than the pure hobbyist on the thermal issues they keep having!
                        what a joke
                        • Make-a-Wake
                          FE Rules!
                          • 6057
                          #132
                          what a joke
                          I wish them luck in trying to delete posts here or on RCG................where it really matters..................
                          Still no 50mph runs out there
                          • skubacb
                            • 3
                            #133
                            "And I changed out the stock TRX (are they rated at 30 amps?) connectors to 4mm gold bullets rated at 93A. "
                            Not a good idea. The bullet connectors do not have the surface area of the TRX connectors. Actually, the total surface contact area of the TRX and Deans is just about the same. That means you will burn up something in the boat before you have a problem with the connectors. Try bursting over 100 amps.
                            Castle has some bullet connects that they recommend for their motors but remember they have three connectors there vice two for the TRX and Deans. Also, the Castle bullet connectors are NOT the banana type. Most all of the bullet connectors out there are bullet type so you actually have to worry about three pieces making full contact, which they don't.
                            • Diesel6401
                              Memento Vivere
                              • 4391
                              #134
                              I just got confused: Are you saying that deans and traxxas plugs are better then CC bullets? You changed to 4mm but you are you saying that wasn't a good idea?
                              * The traxxas connectors and deans connectors are pure junk. Most of my setups will destroy those other connectors so quick it wouldn't be funny. I will stick to Bullets 5.5mm or higher! Also deans/traxxas will get so hot they will de-solder. There is reason why the majority of the people here don't use trx and deans plugs... Simply put they can't hang in most FE setups. I think if you continue to use trx and deans plugs it's only a matter of time before you will find the problems...
                              - Diesel's Youtube
                              - Diesel's Fleet
                              • Panama Jack
                                • 21
                                #135
                                take a close look at a used trx conector and you will see what the real contact area.
