Thermal Issues with the New Traxxas Spartan
  • djmaincheese
    • Dec 2010
    • 347
    Seems like everyone who has the Spartan is having high motor temp issues after about 4-5 minutes of run time on 6S Lipo's. The ESC and Batteries barely get warm but the motor, well thats a different story.
    4S is not a problem on these boats if you only want to do 30mph
    My question is what is a more effective way to keep the motor temps down. If I change to an aluminum water cooling jacket would that possibly help, or do you prefer the thin aluminum coil tubing wrapped over the whole motor.
    Any input would be greatly appreciated
  • Make-a-Wake
    FE Rules!
    • 6057
    Get a new motor............... Leopard makes a 36 x 74 4 pole for 50 bucks, or you could get the Ammo 36 x 88.
    • djmaincheese
      • Dec 2010
      • 347
      And just use the stock ESC with it? Do you possibly have a link for the motor you are referring too? Traxxas recommends a 1600-1800kv motor. Thanks
      • GeoVW72
        • Jun 2010
        • 258
        I have read the traxxas forum. I can find no mention of how the boats are run or if they are maintained properly. The flex-shaft and strut bearing have to be lubricated at the start of each session.
        I do not think that the statement of the esc being warm is accurate. It is shrouded in plastic and sealed in epoxy, the only true way to find the temp is to remove the plastic cover and check the heat-sink directly.
        An aluminum water jacket may help, as it has more surface area than tubing.
        All the videos we have found of the boats show an unusual amout of running at partial throttle, the esc generates a lot of heat under these conditions with minimal cooling flow.
        I also believe that there may be some inconsistencies in the thermal resistors that traxxas is using that cause the receiver to thermal-shutdown, assuming that the receiver is shutting down and not the esc.
        Team Boca Bearings
        S&G Design
        • djmaincheese
          • Dec 2010
          • 347
          Hey Geo
          I grease everything after each run.
          Yeah its definitely the receiver that is shutting the boat down to 50%. The Reciver is flashing red like crazy which according to Traxxas is Thermal Protection but the ESC has a Solid green light, which is good.
          I may try an aluminum jacket and see if that help before I send anything back but I think a better, cooler running motor is in the books in the near future.
          Here is a picture of the ESC, I don't really want to have the open the case to check the temps inside the ESC
          Probably a stupid question but Can the thermal resistors be adjusted/calibrated or do they have to be replaced?
          Thanks for your time
          • Make-a-Wake
            FE Rules!
            • 6057
            If it were my boat i'd go less kv and up the prop a tad. This is one of the Leopard 4 polers, more powerful as well as more efficient. Your stock ESC should be able to handle this motor...............isnt it around 80-100a rated? Run this on 6s.
            • steveo
              • 1595
              are the escs 4 pole for the spartan
              • Rumdog
                • 6667
                Your untimes are too long. 4-5 minutes from what I'm presuming is 6s1p.. Cut the runtime down and check temps throughout the run. The REAL problem is a 540xl can in a 36" mono. It just isn't quite enough.
                • T.S.Davis
                  • 6266
                  I don't own a boat I run longer than 4:20
                  Noisy person
                  • djmaincheese
                    • Dec 2010
                    • 347
                    Im running 2 x 3S2P Batteries 6400mah. I put the boat into training mode 50% power and I went non stop for 25 minutes and 3/4 of the time I was at full throttle.
                    After 4 minutes in Race mode the motor just gets too hot and the receiver cuts the power in half.
                    There is a temp sensor installed on the can at the very front of the motor.
                    I don't mind getting the short run times just so long as it's not the motor thats doing it.
                    Whats the consensus for motor choice in your mono hulls of this size?
                    That leopard looks perfect for this boat and worst case it's only $50
                    Hey steveo, not sure if the ESC is 4 pole, I will call Traxas and find out.
                    • Steven Vaccaro
                      Administrator
                      • 8932
                      I have to say with all the high mah packs out there, 4 minutes of "playing" runtime doesn't cut it!!! This boat should have been stress tested at a minimum of 10 minutes.
                      Steven Vaccaro
                      • jac4412
                        FE Addict
                        • Jun 2010
                        • 427
                        cheese, the issue here is that the stock bare minimum setup they want you to run is 4s... and it appears to run fine on it.. what 30-35 mph? Jumping up to 6s on a RTR boat is a biggg jump, thats a significant amount of change on the esc and the motor especially. I also would take the KV down a bit to keep the motor happy, especially if you want 5 min runtimes.
                        JAC4412 RC
                        • yurkanip
                          • 495
                          agreed, the stock motor a 540xl which is a 2 pole is just too small, period for a 36" mono. They draw much more amps than a cat or hydro. go to a neu, or leopard 4074... 4 pole.
                            • 9481
                            http://www.nitrorcx.com/96m811-3674--1300kv.html
                            That would be a perfect contender in this hull
                            sweet spot kv
                            • Darin Jordan
                              • 9446
                              Darin E. Jordan - Renton, WA
