NEW Pro Boat Impluse 31 RTR V2
recommended for brushless motor max 40000rpm
4s motor 2200kv 4s=4.2vx4=16.8 16.8x2200=36960rpm
5s motor 1800kv 5s=4.2vx5=21v 21x1800=37800rpm
6s motor 1500kv 6s=4.2vx6=25.2v 25.2x1500=37800rpm
motor A3630 imp volt 12-22.2v 50A 4S-5S
motor dynm3830 ???????
max rpm ?????????
Not quite how it works. Multiply by 3.7v not 4.2Originally posted by mannytx1 View Postrecommended for brushless motor max 40000rpm
[ATTACH=CONFIG]86890[/ATTACH]
max rpm ?????????
battery / nominal voltage / maximum charge voltage / minimum discharge voltage
1S / 3.7v / 4.2v / 3.2v
2S / 7.4v / 8.4v / 6.4v
3S / 11.1v / 12.6v / 9.6v
4S / 14.8v / 16.8v / 12.8v
5S / 18.5v / 21.0v / 16.0v
6S / 22.2v / 25.2v / 19.2v
You are both "right"... 3.7 is nominal... 4.2 is optimum... However, there are almost NO, if any, cells that will be 4.2V under any load at all...
You are better to figure out your setups using 3.7 or 3.8V/cell, and calculate from there. And that would be for GOOD cells... VERY good cells might.... MIGHT, hold 3.9 or 4.0V/cell for a very short period of time at the beginning of the discharge cycle (first 20-30 seconds), but even that is a push...
I do all my "guestimation" using 3.7V/Cell...Darin E. Jordan - Renton, WA
Each cell of a LiPo has a nominal voltage rating of 3,7 Volt and a maximum charge voltage of 4,22 Volt (4,2V is standard).
That means the LiPo is used in a "voltage-window" ranging between 3Volt and 4,2Volt.
In contrary to a normal accumulator the voltage of the LiPo cells will not sink below 3 Volt !.
If a cell is discharged below 3 Volt, this will cause irreparable damages. Afterwards a complete charging is not possible and its shelf life is very short.Attached FilesLast edited by mannytx1; 12-29-2012, 11:18 AM.
okay… so the point here is?Originally posted by mannytx1 View Post[ATTACH=CONFIG]0[/ATTACH]
you still multiply by 3.7 to figure your rpm's
