NEW Pro Boat Impluse 31 RTR V2
  • hobby_man
    • Sep 2011
    • 103
    #76
    search youtube for lonmn, I have some spartan video
    • formulafastech
      • Oct 2012
      • 7
      #77
      Is there a need to upgrade the prop
      • mannytx1
        Fast Electric Adict!
        • Oct 2012
        • 99
        #78
        yes 42mm in 5S Turnigy nano-tech 65-130c lipo
        There are many propellers in 42 mm, take care com temperature
        • Niky
          • 61
          #79
          Hi Guys,
          so it seems that the IM 31 V2 is not for 6s with stock upgrade?
          Thanks,Niky.
          • mannytx1
            • Oct 2012
            • 99
            #80
            impulse 31 v2 works in 6s, but is excellent in 5S (most favorable) prop x442
            100_0182.jpg 6s maybe will last 6 months
            • LOVE6S
              • May 2012
              • 521
              #81
              [ATTACH=CONFIG]87277[/ATTACH] 6s maybe will last 6 months
              Are the two new proboats ok to run on 6s? It seems to me if it had a problem with 6s it wouldnt last 6 months, I would think if if it didnt burn up after a fair anount of use, you should be good to go, when somethings not rite, it doesnt take 6 months to burn up. more like 6 min.
              • Niky
                • 61
                #82
                Hi Guys,
                It seems to me that the new IM 31 will have the same pains on 6s as the Spartan had.
                So I give up, I'll buy by OSE STORE the upgraded components for my Spartan and the case is closed.
                Another "sacriface" of 350$ and all the pain will be gone (hope).
                Thanks all,salute Niky.
                • mannytx1
                  • Oct 2012
                  • 99
                  #83
                  I'm happy impulse 31 v2
                  hi,Guys
                  I do not understand, Impulse 31 v2 works excellent in 5S, why put it in 6s
                  what is the obsession of 6s, 6s, 6s ,6S,...... Why?
                  6S is an illness
                  • LOVE6S
                    • May 2012
                    • 521
                    #84
                    what is the obsession of 6s, 6s, 6s ,6S,...... Why? 6S is an illness I dont understand why you would say that, 6s, is a standard, that many a FE BOAT is run on, 4s and 6s I think are you most common power sources people run, higher volts and less kv, draw less amps, and can be a great setup???
                    • mannytx1
                      • Oct 2012
                      • 99
                      #85
                      you love 6s
                      rc boat 4s or cr boat 6s
                      not 4s and 6s
                      I prefer 2200kv 4S
                      I prefer 1500kv 6S
                      • Niky
                        • 61
                        #86
                        Hi Guys,
                        yes, you can say that is my obsession, but now I got 6 peaces of 3s LiPos.
                        You have no idea how much it costs here in Switzerland. I spend almost a 1000$ for 3 couples of LiPo batt. and the charger.
                        There's sites you can order the LiPO for a double less price than here, but it's very likley that you'll never get it because of non comfortibility with swiss law.
                        I know the people who never recived their batt.
                        So i must use what i have, don't wanna spend anymore my money for the LiPo.
                        • mannytx1
                          • Oct 2012
                          • 99
                          #87
                          hi NIKy
                          apology
                          I live in U.S. texas and we have this problem, 6s runs fine with X442 5s and 4s x445 with no heating problems.
                          my temperature here is 90-100f
                          the speeds are different every day with the same settings, dependent on external factors.
                          I am a fan of speed, but I like to take care of my boats
                          Manny, TX
                          • mannytx1
                            • Oct 2012
                            • 99
                            #88
                            Not recommend this boat
                            propeller diameter reduced, back- cuts, balancing and detongueing , sharpening, 42x55 decreases to 40mm
                            connector 4mm Gold
                            cooling hose 1/4x.170 O.DxI.D
                            4S 39.2mph (runs 1 minutes)
                            5S 48.7mph (runs 1 minutes)
                            6S 57.5mph ( runs 1 minutes)
                            1)servo does not work
                            2)esc does not work for high volt cutoff and cutoff type ldle, (can not be programmed with programming card)
                            3)program card will not work
                            I sent back to Horizon
                            Horizon sent me new servo, esc and card
                            • david.garrison
                              • 10
                              #89
                              I desoldered my new version 2 also and had discolored/burned motor wires. And after reading Darin's comments from above, I am guessing that I did not have mine setup well either and I was running 6s. The difference is that Horizon Hobbies/Proboat sent me out another motor and esc. I like the boat, but it guess I need to learn more about setup, but 6s on the stock setup I am not sure about. I have since changed esc and motor and added the dual rudder option for extra cooling and changed to 5.5mm bullets running .187 flex without teflon. I haven't had a problem with the servo (yes the back screws come out at an angle, but it is not that bad). Yes the antenna was a pain ONCE. The hull is solid. I have had issues from day one with water in the boat. I still have not located the area yet.
                              I guess what I am looking for is a boat I can run wide open for 5 minutes without any problems. I am a newbie to RC boats. This is my first fiberglass hull. I am trying to learn the ins and outs of this sport. I guess I made the mistake that Proboat said it would run on 6s and it is a RTR boat.....so I put in 6s and ran it. I also had the top hatch crack on my first crash. Proboat sent another hatch. Horizon and Proboat have EXCELLENT customer service. All in all, This is a good boat. After some mods a great boat.
                              • Niky
                                • 61
                                #90
                                Hi david,
                                that what you say is materializing of my fears.
                                Today, there's no RTR boat that can run on 6s out of box. It's better to buy just a hull with drive hardware and put the ESC & motor depending which batteries you want to run.
                                I'm wondering why don't they make the boat a hundred, two hundred box more expencive, but also qalitativley better. Incredible!
                                Salute all, Niky.
