NEW Pro Boat Impluse 31 RTR V2
  • mannytx1
    Fast Electric Adict!
    • Oct 2012
    • 99
    #106
    heavy fiberglass reinforcement tape inside, and epoxy both sides
    Epoxy in the motor and servo support
    Thanks Darin, I try to improve every day
    I visit Seattle in February, the home of my children
    I will repair
    improved stability with ESC front
    thanks manny
    • Darin Jordan
      • 9446
      #107
      thanks manny
      Manny, when you say "improve stability", can you describe?? I might have some tips that would help... I know a few tricks for this boat that I haven't shared... yet...
      Darin E. Jordan - Renton, WA
      • mannytx1
        • Oct 2012
        • 99
        #108
        HI Darin
        more weight to the front
        batteries more near the CG
        Possible correction torque roll
        improves cooling system
        the antenna of the other side (cosmetic)
        Manny
        • Darin Jordan
          • 9446
          #109
          [ATTACH=CONFIG]91452[/ATTACH][ATTACH=CONFIG]91453[/ATTACH]
          HI Darin
          Manny
          I have found that getting the weight too far forward causes issues... I've had better luck with having the weight at the CG, and then using the tabs to get the nose down. Keeps the ride back at the keel where it belongs...
          A tip to ALL of you... Replace the turn fins with some squared/rectangular fins... For starters, you may just take a set like the Revolt's and modify them to fit. They don't have to be very long... My fins for the P-Ltd setup are about 1/4" above the keel when viewed from the back. Make sure they mount RIGHT up against the transom, and extend down at just a slight angle. Make them about 1.25" or so in chord. You will be AMAZED at the stability you'll suddenly realize, especially in the corners...
          I sent a pattern to Steven and I believe that OSE may be working to produce/supply them for you. Future offerings from Pro Boat will also have this design. It's a "design flaw" that I put into this boat, and the one real "mistake" I think I made when developing it. The straight fins make the boat much, MUCH more drivable in the turns, especially when it gets rough. Try it!!
          • mannytx1
            • Oct 2012
            • 99
            #110
            thanks Darin
            please send me some pictures
            ESC put forward, backward batteries, together CG is nearer
            center of gravity that% to over 45mph???????? 30% o 31% o 32%
            manny
            • mannytx1
              • Oct 2012
              • 99
              #111
              modify the original
              manny
              • mannytx1
                • Oct 2012
                • 99
                #112
                another modification homemade bushing
                manny
                • mannytx1
                  • Oct 2012
                  • 99
                  #113
                  hi, Darin
                  Impulse 31 v2 improved
                  The problem was the color. I change the color and no more problems LOL…..
                  -Battery 5S 4000 mAh 40C
                  -Propeller (Battery 5S, motor timing LOW)
                  42x55 45.4 mph
                  M445 46.3 mph
                  42x55 the tongue removed 47.2 mph (timing high 8% more speed and Amp)
                  M445 reduced to 42mm diameter 50.8 mph (timing high 8% more speed and Amp)
                  -Cooling hose 1/4x .170 O.DxI.D
                  -Connector 4mm Gold battery
                  -ESC front, more weight to the front, batteries more near the CG
                  -CG 30 % 8” ¾ or 9”
                  -Improves cooling system
                  -The antenna of de other side
                  -Reinforcement of the hull and hatch cover with fiberglass and resin
                  -Modify the original turn fins
                  - flex shaft (Miss Geico)
                  -Adjustable trim tabs
                  -Homemade bushing
                  -Hatch lock
                  -The stock 1800KV motor and ESC 80 Amp (only 5s)
                  -weight of the boat 4 ½ pounds without battery, with battery 5 ¼ pounds
                  Manny
                  • olwarbirds
                    Magic Smoke Wizard
                    • Oct 2012
                    • 1194
                    #114
                    Tried a motor and esc swap....leopard 4082 2000kv 180amp esc....on 6S with stock prop ...at 2/3 throttle its running way to dry. Definately a lower KV for 6S is needed, my buddy never could open it up, it was uncontrollable...I dont think a prop change would help at all either....DJ
                    • mannytx1
                      • Oct 2012
                      • 99
                      #115
                      custom rc boat propellers (more speed)
                      • olwarbirds
                        Magic Smoke Wizard
                        • Oct 2012
                        • 1194
                        #116
                        Manny, are you using a ball bearing to get your cup even ? ...Ive got so much to learn about props yet !!! ... DJ
                        • formulafastech
                          • Oct 2012
                          • 7
                          #117
                          Would a Prather 220 be a good prop for the impulse or a octura x440 fit I have these props already that's why I am asking I plan to use 4s 5s and maybe 6s if these props are no good can you tell me a good prop to use
                          • formulafastech
                            • Oct 2012
                            • 7
                            #118
                            Today while I was out driving my impulse I had no heat problems but other problems I was using 6s and it flipped the hatch came and the hatch seal came off to and I lost it cause it sank then the boat is supposed to be waterproof but my servo twitches now and my hatch has a crack I was mad when I lost the hatch seal and the servo twitches but other than that it ran fine but I was running in cool water too
                            • Hor2012
                              • 416
                              #119
                              Where r u in ny
                              2x Aeromarine Pro Challenger 48" F.D.M custom built 12s2p 73mph, Fighter Cat Fantasm Twin 12s2p,UL1,Seducer,Motley Crew, Spektrum Dx3R Pro,(R.I.P Impulse 31, K.O.S Cat) 1/5 scale gas Munster Truck, 1/5 scale gas buggy, GoFastOrGoHomeGoBigOrGoHome
                              • formulafastech
                                • Oct 2012
                                • 7
                                #120
                                yes but i run the boat in nj at my shore sucks i just got the boat and im not going down as much anymore cause my house got flooded also i want to get waverunners cause im turning 16 soon but we will see
