Thoughts on new Geico zelos, are the upgrades worth the extra price
New Geico 36 zelos
Wicked looking boat!Also has a different canopy than the Zelos. ( no scoop on the top) Ordered mine today! Says it will do 75+mh on 6s. Looks to be very stable.A04679F0-F6DF-4C7A-B6E0-138B6D16E0BC.jpg mine arrived yesterday !Last edited by Chevoholic; 06-02-2019, 11:39 AM.
The hull seam has been reinforced around the entire perimeter. Rafael Lopez ran his onto shore at full speed and only suffered a hairline crack across the front bridge. That hull was a preproduction model that did not have as much reinforcement as the production hull does.Originally posted by 1coopgt View PostLooks great . The Hull looks Identical to the Twin 36. Wonder if they made any changes to the hull . Looks like a few upgrades, Extra water pickup, new motors and new strut mounts . 2 thumbs up.
Modifications and upgrades include:
MR4000 receiver for longer range
Extended motor mounts with rear support that can also accept 40mm motors
Revised ESC's with larger cap banks & better cooling
ABC 1716 style Props
Water exits now out the top
Sonicwake 3674 motors
Extended struts with support brackets, makes the boat much more stable at speed
"Lots and lots of hull reinforcement too"Last edited by fweasel; 05-23-2019, 06:16 PM.Vac-U-Tug Jr (13mph)
Using the included series/parallel harness, two 3S packs are connected together in series to create 6S voltage, which is then split with the parallel portion of the harness to feed both ESC's 6S voltage. This is not the optimal way to run this boat, but that harness is provided so that those with only two lipo packs are able to run the boat.Originally posted by 4343 View Postwhat would be the connections for this, if using 2 3s you hook a series up to both packs than parallel to esc, how about the next 2 packs??
The preferred method is to removed the series/parallel harness and run two 6S packs, one to each ESC, or use four 3S packs, connecting two packs together using the option series harness.Vac-U-Tug Jr (13mph)
Im new here not sure if this is right place but got my Miss G Zel;os this afternoon one of the drives is all messed up. Need help.
It’s a cheaper 2 pack setup only useing 2x 3s packs in series then paralleled out to the esc so the both esc receive 6s power without loads of batts. It’s less weight and easier on the wallet but not as good of a set up and the weight of a 4 pack setup helps keep it on the waterOriginally posted by 4343 View Postso if you connect first 2 packs in series, how is the second set of packs connected than parralled out??
