Ok cool. Ya i didn't know about the metal plates because i haven't taken it apart yet. I was just looking with the tray still in the boat. 3 out of the 4 plates came un glued.
New Geico 36 zelos
Anything with metal gears that has the same torque spec as the stock servo. Preferably waterproof so you don’t have to waterproof it yourselfOriginally posted by jhurlbert View PostDoes anyone recommend an upgrade servo? I have no clue what to get other than the stock one witch i guess isn't the greatest. What size and connector type, i guess the stock one in analog..
New Geico destroyed
Just purchased Sunday. New Geico 36. (2) 6s1p 45c
Boat was incredibly fast. 2nd run. Flipped at full throttle. Got it to shore and the right flex shaft was broken.
Brought home and put it on the bench to measure and order replacement. I then noticed the deck and hull seam damage, also the chipped sponson. I think torque broke the flex shaft causing the boat to flip at ~75mph
causing the 6S batts to stress break boat at impact. I did not upload pic but the opposite sponson is cracked also.
I will call Horizon tomorrow but I am afraid they will claim I hit something. I do not think I did as there are no visible signs of impact. Either the prop,sponson or rudder. Anyone have an opinion as to the cause? I think the flex shaft broke causing it to flip.
Thanks
Ok thanks I go with Horizon on alot of models because their customer service is excellent. Another question is that as I am new to current FE's capable of +75mph. Should I expect regardless of of make if it flips at speed should I expect to have major damage?
I am very interested in a Zonda also, will it be an issue?
Yes, Anything running that speed is very capable of sustaining damage.Originally posted by Dalley View PostOk thanks I go with Horizon on alot of models because their customer service is excellent. Another question is that as I am new to current FE's capable of +75mph. Should I expect regardless of of make if it flips at speed should I expect to have major damage?
Agreed, things get real when you start flipping and crashing at 70+ MPH. TFL builds a nice hull. The carbon Zonda's are light, but thin and benefit from some reinforcement if all out speed is your goal. The fiberglass version with the carbon/kevlar inlay can still split at the seams. I've seen pictures of that particular hull with air pressure blowout type damage and the inlay just pulled away from the split seam. If you want to go fast, repeatedly, build your boat accordingly.Vac-U-Tug Jr (13mph)
