Warning: Trying to access array offset on null in phar://.../vb/vb.phar/bbcode/url.php on line 2 Do I Cut Them? - RcBoaters Forum
Do I Cut Them?
  • LiPo Power
    DJI Drone Advanced Pilot
    • 3678
    Do I Cut Them?
    I am upgrading Stiletto with Hyperformance Flex shaft and 3.5 Bullet Shaft Assembly:
    http://www.offshoreelectrics.com/pro...prod=hpi-psa35
    http://www.offshoreelectrics.com/pro...d=hpi-dc1563s2
    Looks like the flex is a little longer than stock.
    Do I need to cut the flex or is it going to work fine the way it is?
    Thanks
    Robert
    Canada
  • CHIEFY_44
    • Nov 2010
    • 254
    i did the same upgrade on my stiletto, you may need to chop a very little bit off the shaft, i am lucky hyperpeformance is only 20 mins down the road so i went to see them and he has a flex shaft there that fits without chopping it if u ring them and ask for the flex shaft with the dark spiral line on it it fits a treat. have you done the brass tube instead of the teflon?? if not i reconmend you do, if u look back at darin's set up bit in here he tells you how to do it and it really does make the difference.
    Socal Fe member, miss gieco castle 1515 1y t-180, blackjack29 stock,insane FE30 p sport castle 1515 1y t-180, insane FE30 p spec ul-1 motor t-120, insane 34"mono neu 1521 1.5d t-180
    • CHIEFY_44
      • Nov 2010
      • 254
      you could also make the flat on the motor shaft longer and move the collet
      • LiPo Power
        • 3678
        Tank You, good staff....
        Robert
        Canada
