Yes
Stiletto First Run w/New Boat
I put some clear silicone in those holes on mine, then pressed it in with the dowls. I'm not sure if they are totally sealed or not from the factory. They should be, but ???Originally posted by ALD View PostQuestion? The hatch attaches with two dowels in the front. After a run when I remove the drain plug some water comes out (not alot but enough) is this normal ?
Can the Stilleto handle a grimracer 42x55 metal prop?
I also sealed around all of the water lines on mine, and around the wires. They pass through double-hull sections, so if any water gets past them, it can get down inside the hull.
Mine stays dry inside now.Darin E. Jordan - Renton, WA
EndPointAdjust = servo travel = same thing
Id ask Darin ( the designer of this boat ) if there are setup tips for the ESC.
Originally posted by ALD View PostNot sure what EPA is on a radio. I have a Dx3s surface radio. I'm thinking adjust the throttle travel to 120%. Correct ?Wayne Schutte PhdCSE BaSE BaEE. Australian, & damn proud of it
YOUTUBE
Oh well, I knew this was going to happen... I chipped the gelcoat on the tip of the left sponson.
Don't ask me how since I have NO idea, I didn't see the missing gelcoat when I got her out of the car, so I must have hit something at home.
I'll try to get some supply at a local marine supply store. Any suggestions for a gelcoat repair kit? Should I use just gelcoat paste? Or epoxy? What about color matching?
It's a small chip, about the size of a small bean.
Thanks.
man, I wish this would bind to a DX6i.NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8s
It DOES!!Originally posted by Brushless55 View Postman, I wish this would bind to a DX6i
Compatible Aircraft Transmitters:
JR12X
JRX9303
Spektrum DX8
Spektrum DX7
Spektrum DX7se
Spektrum DX6i
Spektrum DX5e
Spektrum DSM2 Aircraft Module SystemsDarin E. Jordan - Renton, WA
I've never heard of one being preset to the logarithm mode. In fact, I've never even used one in that mode. I can ask, but I'm certain it does NOT come pre-programmed in that mode. Should be linear.Originally posted by simo71 View PostDarin, can you confirm the preset throttle curve for the ESC?
I have noticed that the "steps" in the ESC are pretty large. Running at full throttle, then lightly backing off, results in a pretty decent drop in throttle. Typical RTR throttle curve.Darin E. Jordan - Renton, WA
yes!Originally posted by Darin Jordan View PostIt DOES!!
JR12X
JRX9303
Spektrum DX8
Spektrum DX7
Spektrum DX7se
Spektrum DX6i
Spektrum DX5e
ALD... I really don't think that "beginner mode" is necessary for most people... in fact, on a tunnel, it may make it tough to balance the boat in the turns.
For the Stiletto, on the stock setup, I'd set the programming like this:
Battery Type: Lipo (assuming you are using Lipos)
Cutoff Voltage: LOW
Cutoff Type: Slow Down
Brake: OFF
Timing: LOW
Throttle Curve: LINEAR
Try that and get used to running the boat. If your temps are good and all is happy, then you can try the HIGH timing setting, which MIGHT (jury is still out with this boat) give you a little more zip...Darin E. Jordan - Renton, WA
first run
had first run on smooth water.....ran great but no 40 mph for sure..... still needs motor angle and hight adjusted to a better position.....darin can u take a pic of your motor hight mounting screws pls and the angle of the motor? that would really help me......funny thing happened to me as i flipped the boat powering it up across its own wake......current going out....its a swim or just wait for it situation....i pull the throttle and the prop is touching the water and i power it in(about 20yds upside down...now i know it didnt do the motor any good underwater but will oil the barrings etc and hopefully it will be fine as i ran it for 5 mins after that and ran fine.....MY RETIREMENT PLAN?????.....POWERBALL
will these take full speed turns?.NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8s
