Stiletto First Run w/New Boat
  • ALD
    • 96
    Thanks, I will do that!!!!!!!!!
    • Flying Scotsman
      Fast Electric Adict!
      • 5190
      Originally posted by andym View Post
      Is this hull going to be available without the leg, esc, radio. Something like a pro package steering set up included but add your own esc, leg, motor, radio ??? This would be great as a lot of us would like to try the hull out but do not want the expense of gear we would not use with full on race set ups?? I think this would be a valid and profitable exercise
      Typical Aussie moron, there is no radio just an RX..read the specs. I doubt that it will be offered as a hull only, but you never know...the copycats will be all over this hull.
      Douggie
      • andym
        More Go Than Show Prop Co
        • 2406
        Great to see you can lower the class of any thread, rx is part of the radio system last time I thought about it. the Tx does not do much with out one.
        • andym
          • 2406
          And perhaps this will defeat the splashers as well
          • ron1950
            • 3024
            i beleave the bare hull is available
            Hull only: Stiletto
            $134.99 [PRB4001]
            • Flying Scotsman
              • 5190
              Damn it Andy, how many beverages did you consume yesterday my Aussie mate...LOOK AT THE SPECS.
              Douggie
              • ALD
                • 96
                After running my new Stiletto, I have found that the throttle between 3/4 and full makes no change to speed. Using a spektum 3S. Does the Throttle Travel need to be at 0 and trim at B25 to get 100% throttle? I'm running with B100%. Batts are new 2s 5300 25c.
                • drwayne
                  • 2977
                  perhaps the manual details 'calibrating the throttle' ?
                  • ALD
                    • 96
                    DX3s manual of no help. Pro boat manual states program transmitter or ESC but no info. Ordered Programing card for boat but looking for info on the forum first.
                    • Insaniac
                      • 425
                      The throttle might need to be "calibrated" by:
                      holding the trigger at full throttle, plugging in the ESC, waiting for the beeps and then releasing the throttle.
                      Support US hobby suppliers
                      • ALD
                        • 96
                        Thanks for the info! I'm sure thats the problem.
                        • GP73
                          • 544
                          What sticker?
                          BTW, I took her to the pond last evening...
                          ...I need a bigger pond now.
                          Originally posted by AndyKunz View Post
                          Are you gonna leave that sticker over the cockpit?
                          Andy
                          • ALD
                            • 96
                            New Stilleto-I just love the looks of this boat/quality is excellent. Little programing is all it needs, I think!
                            I tried calibrating the transmitter. Same 3/4 throttle. I ordered a programing card. Feels like the boat was programed to the Logarithm mode described below? When set to Logarithm mode, the ESC
                            delivers 45% power at half throttle and
                            80% power at full throttle. The Logarithm
                            mode is suggested for first-time boaters.
                            Question? The hatch attaches with two dowels in the front. After a run when I remove the drain plug some water comes out (not alot but enough) is this normal ?
                            Can the Stilleto handle a grimracer 42x55 metal prop?
                            • simo71
                              • 74
                              I wonder if you adjust your EPA on your radio to 120% if that would help? If it is how you mentioned, I see that as an error on Proboat's behalf...Most people who have purchased this boat would have experience & proboat are making you purchase a module that would only be used once to change the one setting, the throttle curve.
                              • ALD
                                • 96
                                Not sure what EPA is on a radio. I have a Dx3s surface radio. I'm thinking adjust the throttle travel to 120%. Correct ?
