Stiletto Race Prep
This is a sticky topic.
  • Darin Jordan
    • 9446
    #211
    Originally posted by Zlui View Post
    I bought a Hyper Performance 3.5 Bullet Shaft, but found that the Allen screws do probably not match the metric system; my 1.5mm Allen key was too small, the 2.0mm too big. Do you have a different system of units for Allen keys in the US, and what would the right key be? ...
    I'm pretty sure the Hyperformance unit is standard sized allens, not metric.
    Darin E. Jordan - Renton, WA
    • Zlui
      • 6
      #212
      Well, "standard" is a question of standpoint, or rather continent, in this case ... in Continental Europe Allen keys is all metric. What size in inches would I have to buy, which is between 1.5 and 2.0mm ...?
      Thanks!
      Zlui
      • Darin Jordan
        • 9446
        #213
        Thanks!
        Zlui
        I suppose..., but "standard" is what they are called here! It's either "metric", or "standard"...
        Since 1.5mm is 0.059055", and 2mm is 0.07874"... I'd say you would be looking for a 1/16" sized, which is 0.0625"... Just a bit bigger than 1.5mm, and a bit smaller than 2mm...
        Standard (SAE) sizes are: 0.050", 1/16", 5/64", 3/32", 7/64", 1/8", 9/64", 5/32", 3/16", etc....
        • Zlui
          • 6
          #214
          OK, thanks, I'll be looking for one of those then. Btw, great boat, overall!
          • LiPo Power
            DJI Drone Advanced Pilot
            • 3678
            #215
            So did anyone try M445 and UL-1 motor on stiletto yet???
            Canada
            • JDCrow
              • Oct 2010
              • 19
              #216
              Here is mine using the kit motor and a Grim 40x52/3 blade
              Still learning the boat.
              Proboat Stiletto 29 / ProBoat Miss Elam Brushless / AquaCraft Miss Vegas Deuce FE Conversion
              • ron1950
                • 3082
                #217
                the m445 is way too big a prop at 45 cm.....i tryed it and a 42x55 and both were way slow cant get the rpm up....so when to a 640 detounged and cutback slightly... it was with the ul-1 motor//...it screems...i almost ran it out of the pond i was so delighted(small pond but u have to turn at the end lol)..so just my 2cents worth but go small size with lots of pitch....
                • Darin Jordan
                  • 9446
                  #218
                  I'm going to disagree with this... the 42x55, back-cut .090", slightly de-tongued, and pitched up to 3.8 or 3.9" is one of the fastest props I've seen behind a UL-1 motor. Now, that was on a VS-1, but still... Stock, then maybe you are right, but if you are going to work the prop... work this one!
                  • GP73
                    • 546
                    #219
                    I'm wondering if egneg could prepare some 42x55s with these specs for us...
                    • ron1950
                      • 3082
                      #220
                      have to send my 42x55 off to egneg as it is useless to me right now..thanks darin for the stats on that prop....
                      • duckbum
                        • Jun 2010
                        • 20
                        #221
                        Approximate speed for this Tunnel out of the box w/2 2S 30C's?
                        Thanks!
                        • mickvk
                          • Jun 2009
                          • 215
                          #222
                          Thanks!
                          I got 35 on day 1 (rough conditions). A little tuning with the height/pitch my get a couple more. I may also replace the teflon with brass to gain some efficiency like the boss recommends. :)
                          • colormegone
                            • Oct 2010
                            • 71
                            #223
                            So is this a good prop for my Stiletto with a UL1 motor.
                            I'll send one out to get prepped if this is the case.
                            Thanks, Roy
                            • hazegry
                              • Jun 2010
                              • 842
                              #224
                              Thanks, Roy
                              look like thats what he said to me.
                              • mickvk
                                • Jun 2009
                                • 215
                                #225
                                February RC Driver just hit my mailbox.... Review of the Stiletto on P. 132.
                                The article's ok but I have to admit I buy it for the pictures :)
