Put a Losi Xcelorin 1/8th Scale motor on the stock outboard tonight. 2400KV 4-Pole, very similiar to a Neu in construction. Used a Neu 1509 water jacket on it, which fits perfectly. Just have to remove the endbell screws to slide it on, the reinstall.
ESC is now a Hydra 240.
Fabbed a plywood radio-box top to replace the platic stock one. I needed a little more room under the lid, and also figured this would be easier to tape down. Would have liked to have made if from some G10, but I didn't have any that was thin/light enough, so this will do. Put a coat of laminating epoxy on it, and it's ready to go.
Going to play with this tomorrow at the Puget Sound Model Boat Club's NAMBA D8 2-lap event. Going to throw an Octua 440/3 on there, a 5200mah ThunderPower 50C 4S1P pack, and see what kind of 2-lap time I can navigate.
This could be interesting!
, if you need to replace the caps just wiggle them until they get free of the epoxy and carefully pull them straight out leaving the contacts attached to the PCB. You can then solder the new caps on those contacts.
