Stiletto Race Prep
This is a sticky topic.
  • giddyuperic
    • Jul 2011
    • 64
    #346
    Okay I have the right flex shaft got mine from hyperformance products and it is the one with the black line spiraling around it. And I bought the brass tubing to make the new housing for it 7/32 is this right? Because when I put the shaft in there it seems really loose? Do I have the right size? Thanks
    • FastVee
      • 659
      #347
      Originally posted by FastVee View Post
      Sent email to Horizon with a link to this thread, will report what(or if) they reply.
      It is allways difficult to solve warranty issues long distance, I live in Finland and even thought of sending the boat back, but that would cost me over 300€ ! -the post is so expensive over here to send anything overseas. -even ups wants over 200€.... -so I will keep and fix this even if Horizon wont help me out here with the parts needed.(not saying they wont, lets see what happens)
      Pate
      I have not had any reply from horizon yet... so nuff said about their customer care
      I just tried the boat with x442 and it went nutz.. -at wot it went fast! -then it took off and flew high and landed hard. Now I need to repair the sponsons. -both cracked at the rear where the tunnel meets the sponson.
      -Pate
      www.youtube.com/rangerpate
      • giddyuperic
        • Jul 2011
        • 64
        #348
        Sorry to hear that. Off topic can someone please tell me if I put a 120amp ESC in the her and run a 3 cell battey will I be fine? It say with the motor that comes with her is a 1800kv and a 120amp ESC you can go to 6 cells but I will just go with the 3 in paralelle. also can I just run the 3cell on the stock 60amp ESC that came with her? And If I put the 120 in her and run two cell 7.4 lipos will it suck them down so fast the batteries won't be able to handle it? Please I hope someone can answer these for me. Tap!! Tap!!! is this thing on???????????????
        • giddyuperic
          • Jul 2011
          • 64
          #349
          What is the up grade prop 42x55 or 40x55? Thanks
          • CHIEFY_44
            • Nov 2010
            • 254
            #350
            The best way for you to go is a 4cell 5000mah pack that way you can place it for the best balance, but u could use 2 packs of 2cell 5000 in series and get good run time imo I would not go the 3 cell option it wont produce enough power u need 14.8 volts
            Socal Fe member, miss gieco castle 1515 1y t-180, blackjack29 stock,insane FE30 p sport castle 1515 1y t-180, insane FE30 p spec ul-1 motor t-120, insane 34"mono neu 1521 1.5d t-180
            • Sway
              • Aug 2011
              • 7
              #351
              Im looking at running 5s on the stock motor. Will the stock esc handle 5s on low timing or do I need to upgrade the esc???? Got all the other upgrades done besides the lipo. I run mine now as is on Thunderpower 65c 5000mah 4s.
              • Driggs
                • Mar 2010
                • 74
                #352
                mine does and 2 other friends do, so far no prob, but we are probably pushing our luck,
                • Sway
                  • Aug 2011
                  • 7
                  #353
                  Horizon said the motor is no problem on 5s. But that esc is another story. Ill give it a whirl.
                  • giddyuperic
                    • Jul 2011
                    • 64
                    #354
                    Put 3 cell in there and she was really fast but I let the smoke out of the ESC. So put a 120 amp in there and will run the 3 cell sunday when I go to the pond. I am telling you with the 3 cell it was smoken fast had to slow way down for the turns not that good at turning yet but out of the turns she was gone!!!!!!!! :) :)
                    • Sway
                      • Aug 2011
                      • 7
                      #355
                      3cell???? I run mine routinely on 4s with zero problems. Its how its meant to be ran from the factory. Its setup for 4s lipo's. Mines between 40-45 as is with the prop I have on 4s and to me its slooooow. Seeking 50+mph. Not racing, more of drag racing/bashing.
                      • Sway
                        • Aug 2011
                        • 7
                        #356
                        Im going 5s and if the esc smokes who cares? Ill slap in a hydra Ice then, no biggie!
                        • giddyuperic
                          • Jul 2011
                          • 64
                          #357
                          Maybe the Esc was bad because I lost every thing but stering. These batteries are fully max for my jet and they burst at 95c so I don't know if that had any thing to do with it. The guy at horizon said would not doubt that the ESC could handle 6 cells. But like I said I could have got a bad one. New one on the way but now I have the 120amp in there should be no problem.
                          • Driggs
                            • Mar 2010
                            • 74
                            #358
                            that's my feeling too, I run mine with a x440 3 blade also, you will snap the flex shaft, I'm trying the hyperformance shaft to see if it holds up, it is a lot better shaft, I have a few videos of mine on 5 cell, also I.dont run 5 cell all the time,
                            • giddyuperic
                              • Jul 2011
                              • 64
                              #359
                              You know I bought all that stuff for the flex shaft and have not broke the stock one. Knock on wood I did loosen the end nut just a hair so it is not so tight and there is a little play. But I am charging batteries right now for tomorrow because she was smoken fast on just three cells. Now I have the 120amp ESC in there she should be okay. When you guys say 5cell batteries is that just one big 5 cell? Or a 2cell and 3cells hooked up together? nI don't mah make a differance because I ran mine on the 2cell 5000mah x 2 made 10.000mah. And the put the 3 cell 3300mah in there x 2 and that is 6600mah and 11.1 . Can you please tell me What is the burst rating on your 5cell set ups ? Thank for any help this battery and boat is new to me. I would just stick them in my jets and fly!!!!!!!
                              • Driggs
                                • Mar 2010
                                • 74
                                #360
                                I run one 5 cell, 30/40 c ,
