ProBoat Stiletto Videos
This is a sticky topic.
  • Steven Vaccaro
    Administrator
    • 8724
    I'm going to start each new rc boat subforum with a video thread. I hope people will post videos only in this area. Lets keep questions in other thread, to keep this clean. Thanks!!
    Steven Vaccaro
  • Darin Jordan
    • 8332
    Just for fun, here is a PodCast from Horizon that talks about, amonst other things, this new boat! Pretty cool!
    Darin E. Jordan - Renton, WA
    • CHIEFY_44
      • Nov 2010
      • 254
      this mine running good at legg lake. http://www.youtube.com/watch?v=wluDNiofuTc
      Socal Fe member, miss gieco castle 1515 1y t-180, blackjack29 stock,insane FE30 p sport castle 1515 1y t-180, insane FE30 p spec ul-1 motor t-120, insane 34"mono neu 1521 1.5d t-180
      • ron1950
        • 3024
        that is running great..now if u can get it to turn around the cornor at any reasonable speed u will have it down.....i never could get it to turn hard with speed at all
        • CHIEFY_44
          • Nov 2010
          • 254
          oh it will turn at speed but its tricky, and i did not fancy having to get in the rowing boat and pick it up so i was just playing with it in a straight line to see if we had the balance right and i think its looking good, to get it to turn i have ease off the throttle let it settle a little then start feeding it back in untill its at full throttle thats how i do it but i still get it wrong sometimes and it either flips or pulls awesome doughnuts :-)
          • ron1950
            • 3024
            mine did the same thing...u have to let off and hope for the best in the turn or it spins out or turns into a submarine lol
            • FastVee
              • 649
              My friends first outing with his stiletto. I have 1 also, but the flex snapped at the first battery pack...so no racing action here . -got the hp parts coming so it would stay in one piece.
              Will be racing these with my friend soon and trying to start friendly racing class some day. -these are so cool compared to monos or cats!
              sorry the video has sound issues
              Pate
              www.youtube.com/rangerpate
              • Darin Jordan
                • 8332
                Guys... do yourselves a favor... on these outboards... open up the holes where the cable goes into the coupler, and also where it enters the stub-shaft... I think I opened mine up to 3/16" or so. Give the cable more room to fit without it rubbing, especially if you don't have your motor lined up JUST right.
                • FastVee
                  • 649
                  Thanks for the tip Darin, will check that the components are lined up perfectly and if needed dremel the coupler/stub a bit.
                  -the boat was working fine for few minutes, but after I changed the stock prop to barr cut S220 the flex snapped. -but it was fast with that s220 for a minute!
                  Ordered these
                  http://www.offshoreelectrics.com/pro...prod=hpi-psa35
                  http://www.offshoreelectrics.com/pro...d=hpi-dc1563s2
                  (for both boats, hoping they fit).
                  -does this stub also need drilling or the flex cutting?
                  Also got the 7/32 brass for the stuffing tube, hoping that is correct size...(no 1 ever mentioned the correct tube dia, only that the .187 flex is tight fit and I´m thinking that 7/32 is correct)
                  Pate
                  • CHIEFY_44
                    • Nov 2010
                    • 254
                    i also snapped a flex shaft in mine and i used a hyperformance flex shaft with there stub and i did the brass stuffing tube like darin say's in his race prep thread on this boat i also made a oiler addapter to make maintance easier this way i can oil the shaft after every run i just use synthetic transmission fluid which seems to work great not had a problem with the flex shaft since mind you i regrease the shaft after everydays running then i can check for wear and tear.
                    Once you hit the sweet spot on setup with these boats they are great fun still tricky to drive but fun, one thing i would do is remove the motor cover to let the motor get as much cool air as poss i did burn a motor out but i was running a very aggressive prop, hope you find the sweet spot soon.
                    • CHIEFY_44
                      • Nov 2010
                      • 254
                      As to the flex shaft if you ring hyperformance and ask the for the shaft with the black spiral line along its length it fits without cutting the other one that you ordered i believe you have to cut a small amount off the end
                      • Driggs
                        • Mar 2010
                        • 69
                        5cell x440 prop low timeing
                        • ron1950
                          • 3024
                          diggs thats moveing pretty well...is that the stock motor?
                          • Driggs
                            • Mar 2010
                            • 69
                            all stock except 5mm bullets, and 5cell 30c4000mah, 3 blade x440, we'll see how long it last...
                            • ron1950
                              • 3024
                              how much work is done to the 440/3? i tryed one and after 2 min it about melted the plastic battery compartment cover......
