ProBoat Stiletto Videos
This is a sticky topic.
  • Driggs
    • Mar 2010
    • 69
    how much work is done to the 440/3? i tryed one and after 2 min it about melted the plastic battery compartment cover......
    its sharpend and balanced, but my friend runs the same setup with a raw prop with no problems, make sure you are on low timeing, it helps with heating issues, I was running a 42x55 2 blade and I was getting to much heat with a 4cell, till I changed the timeing to low, also we ran a 42x55 2 blade with a 5 cell for 3minutes to see what would happen, and it still is running, but who knows for how long...
    • arp1500
      • Jun 2011
      • 146
      cheify44,
      thats running good what power setup you running motor,esc, batteries
      • CHIEFY_44
        • Nov 2010
        • 254
        well in that video its all standard apart from i put the brass stuffing tube in with oiler attachment that darin has recconmended, i also changed the shaft and outshaft to hyperformance parts, i was running a p220 s/b with turnigy nanotech 50004s1p 45/90c rated cells, timing was bumped up to high on the proboat 1800kv motor, next thing i am going to try is a 120amp esc with a ul-1 motor 2030 kv. More details of my setup can be found in darins thread 'what setup works for you'
        Socal Fe member, miss gieco castle 1515 1y t-180, blackjack29 stock,insane FE30 p sport castle 1515 1y t-180, insane FE30 p spec ul-1 motor t-120, insane 34"mono neu 1521 1.5d t-180
        • Driggs
          • Mar 2010
          • 69
          take a ride in my stiletto
          http://www.youtube.com/watch?v=eK51o...e_gdata_player. Chasing around another Stiletto with mine
          • Driggs
            • Mar 2010
            • 69
            stiletto race- wreck
            • jamespl
              • 742
              This is a quick vid of mine taken on my iphone, for some reason youtube kill the quality of the vid but you get the idea. Stock apart from an x640 prop- not my best driving!
              • mountains
                • Aug 2011
                • 34
                Hi guys hope im in the right place, I just got a pro boat f1 took me ages to get it to bind took it out today its got vitually no steering throw I am using a DX3E the tranny has been set to max steering on all controls the titanic could turn in a smaller circle the cables have little slack, whats wrong amy help appreciated. KEVIN
                • Griff
                  • Jul 2011
                  • 65
                  onboard video
                  some on board footage, even some underwater shot at Black Park in Slough U.K. Boat is stock, running on 2x 2s 5000 45c thunder power lipo's
                  first time doing the video stuff so not the best you will see
                  Tom
                  • GixerGuy1978
                    • Nov 2011
                    • 67
                    My Stiletto up here in Canada;
                    ul1 power with aquacraft 60amp speedcontroller. nano-tech 4 cell 5000mAh 45-90C battery all the way back in tray with speed controller tray removed. X440/3 detongued. motor mount modified for more height. motor pitch about neutral.
