hey everyone i am in desperate need of some advice and help. i have a pro boat mystic 29 that i put a leopard 3674 2200kv motor in, also a hobbywing seaking 120amp esc, and a octura sharpened and balanced m445 prop and i am running it on 4S. so here is my problem...when im accelerating at about half throttle the boat is fine but as soon as i give it full throttle the boat majorly picks up power but only for a split second then the boat will only do the half throttle speed as if the power was suddenly cutout. why cant i hold full power without the boat cutting off to half power? please help
HELP PLEASE mystic leo 3674
That setup won't last long on 6s. Put a m445 prop on 4s and your impulse will run 50+ which is more than that hull likes.white geico w/2200kv 3674 leopard 53.5mph 4s2p, geico w/ 1800kv outrunner 52mph on 4s2p, genesis w/2200kv castle 53.8 on 4s2p, impulse 31 w/2200kv castle, stock p1 and ul-1
Also, check your packs to make sure one doesn't have a bad cell causing the lv to cut in.white geico w/2200kv 3674 leopard 53.5mph 4s2p, geico w/ 1800kv outrunner 52mph on 4s2p, genesis w/2200kv castle 53.8 on 4s2p, impulse 31 w/2200kv castle, stock p1 and ul-1
More than likely bad batteries. The LVC cut off limits the power becuase as you accellerate and put a heavy load on your batteries the voltage drops too low and LVC cuts in. Get some new batteries. Run 4S 2p 3000mah. I've had better luck with paralell than seriesOriginally posted by rhengst22 View Posthey everyone i am in desperate need of some advice and help. i have a pro boat mystic 29 that i put a leopard 3674 2200kv motor in, also a hobbywing seaking 120amp esc, and a octura sharpened and balanced m445 prop and i am running it on 4S. so here is my problem...when im accelerating at about half throttle the boat is fine but as soon as i give it full throttle the boat majorly picks up power but only for a split second then the boat will only do the half throttle speed as if the power was suddenly cutout. why cant i hold full power without the boat cutting off to half power? please help
I run the castles on 4s as well.white geico w/2200kv 3674 leopard 53.5mph 4s2p, geico w/ 1800kv outrunner 52mph on 4s2p, genesis w/2200kv castle 53.8 on 4s2p, impulse 31 w/2200kv castle, stock p1 and ul-1
