HELP PLEASE mystic leo 3674
  • rhengst22
    • Aug 2012
    • 72
    hey everyone i am in desperate need of some advice and help. i have a pro boat mystic 29 that i put a leopard 3674 2200kv motor in, also a hobbywing seaking 120amp esc, and a octura sharpened and balanced m445 prop and i am running it on 4S. so here is my problem...when im accelerating at about half throttle the boat is fine but as soon as i give it full throttle the boat majorly picks up power but only for a split second then the boat will only do the half throttle speed as if the power was suddenly cutout. why cant i hold full power without the boat cutting off to half power? please help
    • 7651
    It is your Low voltage cutoff. Do you know where it is set at? I turn mine off,but you need to pay attention to time running then.Seaking are god aweful for this.
    • rhengst22
      • Aug 2012
      • 72
      Why would my low voltage affect whether or not I have full power or not. The batteries are full and I have alarms that go off when my batteries are low. How do I turn the low voltage off?
        • 7651
        The controller intentionally cuts power so that you will bring the boat in and save your lipo's. You have to go over the programming to turn it off. I have that info right here if you do not.Do you have the program box or going with beeps.
        • rhengst22
          • Aug 2012
          • 72
          Do not have program box....have no info never programmed ESC before...any info would be greatly appreciated
            • 7651
            Ok give me a few minutes and I'll see if the instr are online somewhere. If not I'll have to brief you.
              • 7651
              Found it, Here you go http://www.hobbyhot.com/hobbywing/ho...uals/HW-15.pdf
              • rhengst22
                • Aug 2012
                • 72
                Thanks a bunch...OK now that I am programming.....what should my timing be on this setup as well as my other setup...a impulse 31 Leo 4074 2200kv 6S m440?
                  • 7651
                  We should know what the wind of the motor is.It will be either a D wind or a wye wind.5-7 for D and 11-15 for wye.That thing should move well.
                  • stadiumyamaha
                    • 1284
                    That setup won't last long on 6s. Put a m445 prop on 4s and your impulse will run 50+ which is more than that hull likes.
                    • stadiumyamaha
                      • 1284
                      Also, check your packs to make sure one doesn't have a bad cell causing the lv to cut in.
                        • 7651
                        Aw crap I didn't see that 6s.I don't even do that.
                          • 7651
                          I see a 2150kv that is 2Y wind.I run my Castle 2200kv on 4s and an occasional 5s run.M445 or M645 prop.
                          • mtbenjamin77
                            • 761
                            More than likely bad batteries. The LVC cut off limits the power becuase as you accellerate and put a heavy load on your batteries the voltage drops too low and LVC cuts in. Get some new batteries. Run 4S 2p 3000mah. I've had better luck with paralell than series
                            • stadiumyamaha
                              • 1284
                              I run the castles on 4s as well.
