I need help with motor and esc
  • Dalejr88
    • 6
    I would like to know what motor and esc to use. I won't to run in the 60+mph.
    • 6057
    How many cells lipo are you wanting it use?
    • Dalejr88
      • 6
      T think 4s is the biggest I can get in the boat. I'm new to boats
      I have 1/10 on road cars nitro. I need lots of help.
        • 6057
        Leopard 4082 2200 kv with an x642 will get you up into mid to upper 50's.......................i believe the canopy clearance is not an issue on the Mystic.
        You may even try an x645 but need a 180+ amp ESC minimum.
        • Dalejr88
          • 6
          Just ran the boat stock motor and esc ose upgrade flex shaft
          45mm cnc 3 blade prop from mhz. Esc set on hard timing.
          Motor temp 109 esc 124 after two sets of battery's battery temp
          120. Melted red wire from motor at solder connection to
          Bullet connector. R my temps to hot? Out side air temp in the 80s
            • 6057
            Running a 3 blade 45 mm is like running a 2 blade 48mm prop, too much heat at the solder joints. Sounds like the ESC and motor survived it.
            • Dalejr88
              • 6
              Do u think that's to much prop? Will that prop work with the 4082 motor and 180 esc? Is that y my temps r higher?
              • gtrcguru
                Radio Control Guru
                • 185
                u need to change ur motor connections to 6.5mm or better and ur batts to 5mm. the connections seem to be the week link in all these fe boats.
                used to own a mystic. i was running a sf 200+ and cc 2200 w/ m645 all 6.5 connections. i was running upper 50's with no meltdowns. everything nice cool
                58" Venom Segad-48" Prather Deep Vee-41" Dumas 1/8 Hydro-34" Saga C1-32" Venom KOS P1-31" Pro Boat Impulse V1
                • Dalejr88
                  • 6
                  Thanks for the input. I think I'm going with the 8mm to be on the safe side. I'm upgrading the motor and esc to the 4074 and 180 seaking. Do u think the prop is to big?
                    • 6057
                    Try an x642 if its the 2000kv 4074, or an x640 if its the 2200kv.
                    • Dalejr88
                      • 6
                      Thanks for all the help. I will let u guys know how it works out.
