I would like to know what motor and esc to use. I won't to run in the 60+mph.
I need help with motor and esc
How many cells lipo are you wanting it use?Last edited by Make-a-Wake; 09-29-2012, 01:02 PM.NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:
Leopard 4082 2200 kv with an x642 will get you up into mid to upper 50's.......................i believe the canopy clearance is not an issue on the Mystic.
You may even try an x645 but need a 180+ amp ESC minimum.NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:
Just ran the boat stock motor and esc ose upgrade flex shaft
45mm cnc 3 blade prop from mhz. Esc set on hard timing.
Motor temp 109 esc 124 after two sets of battery's battery temp
120. Melted red wire from motor at solder connection to
Bullet connector. R my temps to hot? Out side air temp in the 80s
Running a 3 blade 45 mm is like running a 2 blade 48mm prop, too much heat at the solder joints. Sounds like the ESC and motor survived it.NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:
u need to change ur motor connections to 6.5mm or better and ur batts to 5mm. the connections seem to be the week link in all these fe boats.
used to own a mystic. i was running a sf 200+ and cc 2200 w/ m645 all 6.5 connections. i was running upper 50's with no meltdowns. everything nice cool58" Venom Segad-48" Prather Deep Vee-41" Dumas 1/8 Hydro-34" Saga C1-32" Venom KOS P1-31" Pro Boat Impulse V1
Try an x642 if its the 2000kv 4074, or an x640 if its the 2200kv.NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:
