perfect MG
  • iop65
    • Mar 2013
    • 367
    perfect MG
    finaly achieved the perfect running MG!
    bought a used MG 29 v2 a few weeks ago for a really good price, i'm more into mono's but for that price i could not resist
    the guy only ran it for a few times and put it on the shelf
    tried it bone stock and understood immiadiately why it was sitting on the shelf -:)
    blueprinted the sponsons ,raised the strut : bottom 2 mm above sponsons 0° angle: in chopy water boat ran great , the flatter the water the worst the bouncing was and the bow came up
    blueprinted it again but now made the angle of the last sponson 90° ,was about 100-110°
    lowered the strut :front 1.5 mm and back of strut 1 mm above sponson ( slight negative angle)
    ran it today and this was what i was aming for , the bow only slightly above the water ,running full on the last to steps
    water was not glas , slight chop ( like the lake is most of the time),so can not tell what it is doing in flat conditions but in looks just perfect ( boat is running almost flat) in conditions that i usely encounter
    1500Kv stock motor
    90A seaking esc
    2 and 3s 4000mah (5s)
    40 mm 1.4 p carbon graupner k-prop
    it was a lot af work but it paid off !
  • iop65
    • Mar 2013
    • 367
    some pictures
    • iop65
      • Mar 2013
      • 367
      as you can see i changed the inner layout because i hated the way the lipo's had to be attached with velcro
      used 4-7 mm cooling tube to compensate for the longer distance to esc ( just in front of motor) ,has to shorten it still a bit but is a big improvement over the 3 mm tubes and cooles good
      glued a 2 mm PS piece on the last sponson in a 90° angle and filled the gap (2.5MM!!!)
      blueprinting looks rather messy ( the black /yellow/white/filler/PS) but is smooth as silk and corners are razorsharp
      changed the stand , boat sits much more stable like this but i'm going to make something different this winter
      first time out i hit a buoy ,boat was all over the place very hard to run it , and off course i hit something
      that is why the tip off the sponsons are black
      • iop65
        • Mar 2013
        • 367
        tested it on flat water this morning (the few times the lake is flat ) ; bouncing is still there but lower frequency and the bow doesn't come up as high as before but still not what i want
        i want it to run flat in all conditions to have a save non-blow over hull to test out higher speeds ( now 64 km/h with the small 40 mm 1.4 p)
        thinking of glueing 1.5- 2mm ride pats
        this will give more ways to get a negative angle and adjust the hight prop-water , it is just impossible to bend the stuffing tube to the desired angle and hight(prop-water) now!
        • BHChieftain
          Fast Electric Addict
          • 1964
          You need to grind a space in the strut adjustment slot so you can adjust the negative angle correctly. See this thread. At the end is a video of the boat with the correct strut adjustment plus blueprint result (90degree edge). I am really happy with this result.
          http://forums.offshoreelectrics.com/...t-modification
          Chief
          • iop65
            • Mar 2013
            • 367
            i did that Chief
            the problem is the stuffing tube comes out off the hull in the wrong angle and it is impossible to bend it without damaging something (stopped trying that)
            it needs to get higher and more angeld downwards and it can not be done like it is now , when i set it to the desired height i can only bend it to -1° angle
            • BHChieftain
              • 1964
              You do need to bend the stuffing tube gently by hand. Someone else suggested using a drill bit to help hold the shape.
              Chief
              Sent from my XT890 using Tapatalk 2
                • 4297
                I just leave the flex shaft in it when trying to bend and mod it to help with keeping it's shape.
                • iop65
                  • Mar 2013
                  • 367
                  i also leave the flex in to atchieve smooth bends , but in this case it's just not bending
                  even if it would bend it woud need a S-shape because it comes out of the hull to low ,needs to go up ( to get the correct dept of strut)and then bend it downwards again (to get a negative angle in the strut )
                  really don't like that!
                  but thanks for the suggestions guys
                  • iop65
                    • Mar 2013
                    • 367
                    started this weekend
                    extra 2mm added
                    • BHChieftain
                      • 1964
                      Hi,
                      Are you going to do the middle section of the sponsons or just the last section?
                      Chief
                      • iop65
                        • Mar 2013
                        • 367
                        Hello Chief,
                        no i'm also doing the middle section and about half the first section ( so 2 X 3 sections total)
                        put them on this morning and the second coat of putty is curing ,need to get some abrasive paper,takes a lot of work to get i like i want
                        hope that al the work is going to pay off !
                        • BHChieftain
                          • 1964
                          This is a great idea-- I can't wait to see how it works!
                          Chief
                          • iop65
                            • Mar 2013
                            • 367
                            me to Chief!
                            i will let you guys know even if it was just a useless work without results
                            • iop65
                              • Mar 2013
                              • 367
                              finished
