perfect MG
  • BHChieftain
    Fast Electric Addict
    • 1964
    Had a chance to run her yet?
    Chief
    • iop65
      • Mar 2013
      • 367
      No Chief , will run her this week
      very hot the last few days/weeks, a lot of people swimming/playing/sailing/surfing in the lake where i "test-drive" just to dangerous
      don't want troubles
      • iop65
        • Mar 2013
        • 367
        sad to say things didn't get better ,bouncing was just the same
        can not get the bouncing stopped on flat water , no fear off blow over but still bouncing
        must say it was faster and riding on just a few cm hull and the prop !
        changed the cog to the rear because i thought that more neg angle was the solution but it wasn't
        will change the cog back to what it was at 24/07 and try again this weekend
        perhaps the boat needs extra weight?
        just using 2 and 3 s 4000mah and a 90a seaking
        maybe some extra weight will keep it flat?
        • SloHD
          Slow Electric Addict!
          • Apr 2013
          • 337
          Are you talking about center of gravity/balance when you say pog? Does 24/07 mean the cog is 7 inches from the transom?
          • iop65
            • Mar 2013
            • 367
            no when i was testing on 24/07/2013 my lipo's were about 5 cm (2 inches) more to the front
            going to do that again
            the only way that the bouncing stopped yesterday was by moving the strut up so far (about 3-3.5mm above sponsons) that the speed was going down big time
            then it runs flat but speed is gone
            found out yesterday that to much neg angle made the boat "fishtailing ?" badly but doesn't stop the bouncing at all
            • iop65
              • Mar 2013
              • 367
              ran her yesterday ,little chop
              front lipo's at the back of motor
              0° angle strut
              strut 2,5 mm above sponsons
              runs flat ,cuts through the corners like a knife ,seems it doen't mind the chop at all (no risk at blow over), seems it needs the chop to get flat
                • 9438
                Squaring off the rear of the sponsons after blueprinting works well for me. Never bounces...
                AQ 1800kv, AS/SF120 esc, Zippy 30C 2 x 4S 3000's, M445 for 4 min race and D/T 447 for 6 lap sprint. Strut is level with sponson bottoms and 0* flat. No wood inside with OSE CNC motor mount. Home made rudder offset + aftermarket FG cowling for weight.
                • iop65
                  • Mar 2013
                  • 367
                  tried something yesterday
                  glued (thin dubble sided tape) a 1mm plastic sheet on the end of the last step to create some lifting force
                  boat drives completely flat ,but speed came down a lot
                  did the same this morning ,but now 0.5mm plastic sheet and only 20 mm wide:still nose down but much more speed!
                  think i'm putting on trimtabs
                  i never had the need for trimtabs on my mono's ,other that adding bling-bling for the kids but i see no other way to keep this hull from bouncing on flat water
                    Did you ever get around to putting trim tabs on and if so what was the result?
                    • iop65
                      • Mar 2013
                      • 367
                      yes i did
                      it helps but costs a lot of speed ,removed them
                      it just doesn't seem rigth : a cat with trimtabs
