Warning: Trying to access array offset on value of type null in phar://.../vb/vb.phar/bbcode/url.php on line 2 Bow weight a band-aid? - Rc Boaters Forum
  • SloHD
    Slow Electric Addict!
    • Apr 2013
    • 337
    Just try to bend it some more. Make sure you be gentle. As you probably already know. Fwiw my mystic doesn't like quite that much angle. Try a little less angle. Also give some more space between the strut and the drive dog. Spacing there should be about the size of your flex shaft. Just pull it out about 1/8"+ from where its at now.
    What prop is that?
    • Shane_744
      Choppin' it up
      • Sep 2009
      • 92
      What prop is that?
      The prop was pushed up all the way forward to make sure i clearanced the strut bracket enough.
      This prop recommended by Steven.
      http://www.offshoreelectrics.com/pro...od=cnc-4314250
      TEAM Crawler Innovations, TEAM Holmes Hobbies, TEAM BC Paints!, TEAM OTTSIX , TEAM Y-Town Crawlers
        • 4297
        Hi,
        Why do you have two nut on the prop shaft ?
        If you take one off that would let you move the drive dog back some,
        And that would give you the gap you need at the strut and dog.
        Also do you have any pictures of the lay out of the setup in the hull with the cells in place,
        Like for rtr at the lake ?
        • 1truckerdan
          • Aug 2011
          • 329
          Looks like he is using the 2 nuts to "lock" them together so it stays tight.
          Looks like there is enough thread left to move the drive dog back some and keep both nuts on
          When you know it all.......you never will learn anything new
          • Shane_744
            Choppin' it up
            • Sep 2009
            • 92
            Hi,
            I dunno, there were two nuts with the new setup so I assumed they were supposed to go like that Lol. Ill need to research why they sent two nuts.
            Ill get a few pics of the battery setup soon.
            • SloHD
              • Apr 2013
              • 337
              It's called a jam nut. It comes with the kintec upgrade shaft. Although when I ordered one a few months ago he didn't put one on with mine. I just use a normal ose prop nut, and an octura bullet.
                • 4297
                I never used jam nut on any of my boats,
                Just a nut or a small piece of fuel line to hold the prop on for speed run testing and sport running.
                • Shane_744
                  Choppin' it up
                  • Sep 2009
                  • 92
                  Kintec was out of the bullet prop nuts when I got my order.
                  Here is about where my batteries go. I have moved them all the back and up to about where they sit in this pic.
                    • 4297
                    They look like short packs,
                    Try them a with the balance wires at the middle of the water jacket.
                    • Shane_744
                      Choppin' it up
                      • Sep 2009
                      • 92
                      They are these packs.
                      http://www.valuehobby.com/power-syst...hard-case.html
                      I tried moving them up but not after I have done the strut mod. Been letting the boat dry out all day and have to epoxy a broken battery tray.
                      I started this thread really to see if I needed to add more weight up in front of the motor because moving them backwards was resulting in more lift. But I think My strut angle needs readjusted too. Working on that. Then ill play with battery locations.
