Bow weight a band-aid?
  • Shane_744
    Choppin' it up
    • Sep 2009
    • 108
    Been running my MG and tuning on it. The front end lifts at full throttle. I managed to flip it this evening but I think everything is on. Lost the clear hatch.
    I have the Kintec offset rudder setup, kintec drive shaft, CNC 43mm x 2.38
    Pitch prop. Seaking 180 with a Leopard 4082
    2000kv on 4s.
    Strut is moved up to where the prop is a few mm from the bracket.
    Ive been moving the batteries around and moved the strut a time or two. Still getting pretty good lift up front to where the prop is the only thing is in the water.
    So long question, short. Will some additional weight help up in front of the motor? Or keep working at the strut setup?
    This evenings pic.
    TEAM Crawler Innovations, TEAM Holmes Hobbies, TEAM BC Paints!, TEAM OTTSIX , TEAM Y-Town Crawlers
  • Heaving Earth
    • 1929
    If you set the boat on a table how much gap between bottom of strut and table top?
    From what I've noticed, when the prop is too deep on cats, it tends to dig in and want to flip the boat.
    • BHChieftain
      Fast Electric Addict
      • 2051
      You want the strut up high-- my son's GEICO is set with prop shaft about 3/16 above the bottom of the strut but you need a bit of negative angle on the prop shaft. You need to grind some extra space in the strut adjustment slot to allow that. Look at my miss GEICO thread for more info.
      Chief
      Sent from my XT890 using Tapatalk 2
      • BHChieftain
        • 2051
        PS, adding weight to the bow will just make bouncing worse. My sons packs are a bit behind the front of the motor.
        Chief
        • Chilli
          • 3204
          Where is your CG at? What is the angle of the strut?? Put a little negative in it (down in back) to keep the nose down. Pushing the strut back down will also lift the rear which will keep then nose down but it will put more load on the motor.
          Mike Chirillo
          www.capitolrcmodelboats.com
          • Shane_744
            Choppin' it up
            • Sep 2009
            • 108
            Thanks guys. I have the strut hole enlarged. Been reading alot and made some nice changes to the boat from this forum.
            Here is where the strut is at now.
            The front end lift seems to get worse when i move the batteries back, with this strut setup. I couldnt move the batteries forward cause i flipped it and soaked everything.
            Not sure about my CG just yet. I need to read up on how to do that.
            Right now the stuffing tube wont let me point the driveshaft down without binding it up. I have bent the tube a little to get where im at now. I may need to make the strut adjustment hole
            Larger and see if that is where its limiting out.
            Edit. Looking at some other pictures of MG struts mine is too level as it sits?
            • Heaving Earth
              • 1929
              Just raise the strut up higher and try. Forget about angle for now
              • Shane_744
                Choppin' it up
                • Sep 2009
                • 108
                Ok. Prop is about 2mm from the bracket. Grind away some clearance if needed to raise it further?
                • Heaving Earth
                  • 1929
                  Lemme guess the prop is almost hitting? Get it as high as possible. The inline rudders really suck if you ask me. There's one reason why right there
                  • BHChieftain
                    • 2051
                    I think this looks pretty good to start, I would not go any lower... my son's boat is about this high but has a tad more negative angle on the prop shaft. With lite chop he has no bounce at all, and on glass water has a slow bounce (means the ride pads need to be blueprinted, but the boat races in p-limited offshore which generates enough chop to break the suction so we have not bothered with that). You'll need to grind the adjustment slot to make room to adjust the prop shaft down more, and you'll very gently need to bend the stuffing tube to align it (be careful!!!).
                    http://forums.offshoreelectrics.com/...t-modification
                    Before messing with that like Heaving Earth says try the full upper range with the max neg angle you can muster for now.
                    Chief
                    • Shane_744
                      Choppin' it up
                      • Sep 2009
                      • 108
                      Thanks guys.
                      heaving, im running the kintec offset but I may cut a triangle off the rest of the stock bracket to be safe so the prop wont be close.
                      Doesn't make sense to me to use the offset rudder setup if the prop is going to be close to the bracket. I thought the point of the offset was to get the rudder out of the prop wash cone? So with the prop still being close to the bracket cause its moved up, the bracket is in that prop
                      Wash cone. Anyways, just thinking out loud.
                      Chief,
                      I figured I would need to grind more on the strut
                      Hole to move it further. Ill try that this evening. Im maxed out on negative angle now.
                      • Heaving Earth
                        • 1929
                        Uhm, ya lost me a bit there, but IMO the offset rudder has many advantages.
                        1 the rudder is out of the prop wash
                        2 it makes getting the flexshaft out for lubrication easier
                        3 takes the bracket out of the way for moving prop up
                        Now, with that said, I know that even with the offset, the bracket still has overhang that gets in the way. If it were me, I would remove any excess bracket above the prop not needed, and get that strut up like 3/16 to 1/4" above bottom of sponsons.
                        Maybe drill new holes for the offset closer, and cut away all that overhang?
                        • SloHD
                          Slow Electric Addict!
                          • Apr 2013
                          • 337
                          I swear I've seen a post with pictures somewhere that some guys just rounded off the bottom corner of the mount. I don't think it's on this site tho. It's the same hardware I chose for my elam so I need to do it as well...
                          • Shane_744
                            Choppin' it up
                            • Sep 2009
                            • 108
                            I was referring to the fact that we go to all the effort to get the rudder out of the prop wash but the strut bracket is now millimeters from the prop (propwash). I am curious if the prop being that close the bracket effects the prop wash "cone" properties. Or does it even matter if things are in the prop wash "cone" behind it?
                            I have cut marks on the rear of the bracket now. Will drilling new holes and moving the rudder closer to the hull have any positive or negative effects?
                            I have seen a few too. Through OSE and google image searches.
                            • Shane_744
                              Choppin' it up
                              • Sep 2009
                              • 108
                              This is where I am at now. To get the prop to have some negative angle the stuffing tube and lower strut are not jiving now. I tweaked the stuffing tube before but it seems like it wont bend to the correct position now. Almost like I will need to trim some off the end of the tube
