The Geico comes standard with the plastic 1.6 in x 2,5 in prop. What is a good replacement prop to use?
What Prop to use with standard setup
Tags: None
X642 is a good prop for the stock setup.white geico w/2200kv 3674 leopard 53.5mph 4s2p, geico w/ 1800kv outrunner 52mph on 4s2p, genesis w/2200kv castle 53.8 on 4s2p, impulse 31 w/2200kv castle, stock p1 and ul-1
I liked the grim 42x55 the most on my MG. The Hull seems to like less pitch. A s220 might not be a bad choice either, but watch the temps .
I would run a s215 on the stock motor seaking 120 and 5s for a good cheap killer setup. :)
Make sure you replace the stock micro 3.5mm bullets with some 5.5mm and dump the deans for 5.5mm or ec5. The increase in amp draw from the x642 will cause issues in the stock connectors.
Samsung Galaxy III via Tapatalk
