What Prop to use with standard setup
  • Gary Cape Town
    • 9
    The Geico comes standard with the plastic 1.6 in x 2,5 in prop. What is a good replacement prop to use?
  • GatorsFan
    • Aug 2012
    • 34
    you may want to look at the prop that is made for the mystic 29
    • dana
      • Mar 2010
      • 3660
      X642 is same prop only beryllium copper
      • martin
        • 2881
        The x642 has 2.64" pitch, the Proboat props either in plastic or stainless have 2.5" pitch.
        • stadiumyamaha
          • 1371
          X642 is a good prop for the stock setup.
          • dana
            • Mar 2010
            • 3660
            Ok so there is .14 difference... Which is almost nothing. For upgrade use x642
            • Gary Cape Town
              • 9
              Thanks, ordering X642 prop
              • Diesel6401
                Memento Vivere
                • 4391
                I liked the grim 42x55 the most on my MG. The Hull seems to like less pitch. A s220 might not be a bad choice either, but watch the temps .
                I would run a s215 on the stock motor seaking 120 and 5s for a good cheap killer setup. :)
                Make sure you replace the stock micro 3.5mm bullets with some 5.5mm and dump the deans for 5.5mm or ec5. The increase in amp draw from the x642 will cause issues in the stock connectors.
                Samsung Galaxy III via Tapatalk
                - Diesel's Youtube
                - Diesel's Fleet
