"that" miss geico
  • masonis1
    If you cant control it 👍👍
    • 1173
    #106
    So made the hatch more aero. Hah and it looks cool.
    Sent from my SPH-D700 using Tapatalk 2
    When speed isnt the option, change your ways
    • masonis1
      • 1173
      #107
      So sanding the boat. To get best results so I.sand down to.bear hull or until everything is smooth
      • roadrashracing
        • 1462
        #108
        the new hatches are plastic if you are looking to replace it
        • masonis1
          • 1173
          #109
          I like the modifications I have done to the hatch.
          Also.found. That I can remove the.blue on the hull.with nail polish remover
            • 7651
            #110
            Looks good Mason.Nail polish remover?Mmm be careful if you clear it later,Brands and stuff.Do a test first and be prepared to sand it off .
            Hey,I did another vid from the weekend.I raised the strut 2.5mm to keep it on the water better .
            • masonis1
              • 1173
              #111
              Nail polish remover. I still.have lots of work to do on the boat still.
              I.have the bottom of the.sponsors still and I will.remand top and sand bottom.
              • masonis1
                • 1173
                #112
                That's the same video I think. Still wheelies
                • masonis1
                  • 1173
                  #113
                  So its starting to look.good. I.think.all the blue will be off tomorrow night THEN. I will resand and clean tomorrow. I will also put a second coat.on the inside. This time I will tape the outside of the.hull. The top was very smooth with the 600 grit. Smooth.as glass. Now if I could get the finished paint to.be that smooth. Any tips. Also tips on tears and checkered. I talked to my gpa today and he has body filler and is up to the task. This should be fun. I will test after blue printing before I paint.
                    • 7651
                    #114
                    Sorry Mason Don't know how that happened http://www.youtube.com/watch?v=22rwnRaB6Dg
                      • 7651
                      #115
                      So are you wet sanding?Walmart has ducttape in flames bubbles and checker.I haven't done checker from scratch yet.Dana on her I believe gets some from hobby king.
                      • masonis1
                        • 1173
                        #116
                        A lot better withbthe 645. Looks good shawn.
                        • masonis1
                          • 1173
                          #117
                          I am wet sanding. I findout u.don't dip the sabdpaper butbspray with a spray bottle then sand. Seems good. I donto really see a difference in wet and dry.
                          • masonis1
                            • 1173
                            #118
                            Would duct tape we put on last and is itblike duct tape material and thick or should I buy decal sheets from my lhs
                            • masonis1
                              • 1173
                              #119
                              How do I do tears?
                              • masonis1
                                • 1173
                                #120
                                So tomorrow I.plan on getting rid of the rest of the blue. Also do I need a primer since there is still paint? also should I add some expanding foam in the sponsors to strengthen the hull? I will possible start blueprinting Friday and continue Saturday. After that I have a camp at mizzou for wrestling but the next week I will paint the boat. I will resand AGAIN and clean. I am now wondering what my base coat will be if I choose to use that boat I chose to copy paint. Would the base be green with the blue on top then checkered flag?
