"that" miss geico
    I would primer it and wetsand to get it perfect.The primer will fill any scratches and stuff. Your LHS may have stencils.Parma has what they call paint mask and have tears in that product.I believe they have checkers too.I would wait to paint if you can order some.This is where the patience comes into play Mason.You have to look at the final product over and over again.So some time getting it right will pay off later with the pride you will have in it when someone walks up and says "cool" at the pond.
    • masonis1
      If you cant control it 👍👍
      • 1177
      #122
      Yep. Ill check that out. So back to blue printing. Any tips
      Sent from my SPH-D700 using Tapatalk 2
      When speed isnt the option, change your ways
        Here is a link to the Parma masks http://www.shopatron.com/products/ca...089.5921.0.0.0
        Look around at them.If you click on the yellow pic they will blow up.
        • masonis1
          • 1177
          #124
          So with those I would paint blue then apply.and paint green? wb the.checkered
            You need to start with some 320grit and you should use a firm or hard chunk of wood/metal as a block.If you keep the sandpaper tight on the block you will keep the edges sharper.You only need a 2" X 3 or 4" block.You also need a straight edge to check for dips on the flats.You'll have to see how well the filler you Grandpa has will stick to the hull.I dabbed it on the corners in order to get them square and sharp.I'll take some pics of mine after work tommorrow to show you.OK?
            • masonis1
              • 1177
              #126
              Sounds good. I.won't even be able too look at this. I have wrestling camp this week too. Hah I want to least get the hull blueprinted before I leave for Italy because NOTHInG will be done for 4 weeks. I am starting to think maybe have someone paint this for me if the price is right
              • LarrysDrifter
                Big Booty Daddy
                • 3416
                #127
                Wet sanding helps keep fine sand paper from clogging and causing gouges/deeper scratches in paint or primer thats being sanded. Using a spray bottle, use Dawn dish detergent and warm water. Spray on hull and paper. Let the paper do the work. When the paper shows signs of not sanding like it should, use a new piece. It pays to not skimp on sand paper if youre going after a nice paint job. Remember, the paint only looks as good as the body work underneath. After doing body work on my old car, ive learned ALOT. It makes a difference to not skimp on anything.
                  You could go either way with those.It depends which way feels easier to mask to you.You just use them as the outline then mask the rest.I have been known to cut them up and use them as neccesary.I used the splash one here
                  • masonis1
                    • 1177
                    #129
                    I will start adding soap when I sand. I am gonna put the paint prep off until I finish blueprinting so I don't mess up it.
                    • masonis1
                      • 1177
                      #130
                      So finished sanding and removed all blue. I only sanded the sides and top. Not the bottom since we are blue printing. But here we go.
                      Wetsanded with soapy water... In febreze bottle... And it turned out great. Silky smooth.
                      • masonis1
                        • 1177
                        #131
                        r
                        crack where I glued it shut.
                        filled in cup area in frnt and divit in the rear as spotted by grey puddy
                        all ready for paint.
                          Looks good Mason.Good work.
                          • masonis1
                            • 1177
                            #133
                            Thanks. The inside is nice with the green and cleans with a wet wipe. Really nice. Now the paint. Last time I tried sanding in between coats. The color turned.mate and.dull. How.can I.fix this? thatbwas when I.wet sanded bybdippibg the paper tho. Hah
                              Clear at the end,Clear at the end.
                              • masonis1
                                • 1177
                                #135
                                It will be clear at the end or what
