Confused on what prop to start with?
  • LiPo Power
    DJI Drone Advanced Pilot
    • 3678
    OSE main site or swap shop...
    Canada
    • Blockhart
      • 39
      or Chuck, all though I shouldn't say that cus he's backed up and I'm waiting for props my self
      Miss Geico?
      • d.a.v.e
        • Jan 2011
        • 230
        So after playing with a few props for too long I suppose, I let some of the magic smoke out of my stock ESC, for some reason it will now only work with 1 4c attached but not 2x2c's in series or 2x4c in parallel? I ordered a new Sea King 180 & Eagle Tree system to attempt to avoid this issue again :)
        With the upgrade to the ESC is the m445 the way to go or are there other suggestions?
        • maxmekker
          • 466
          Mine on 2x 4s (and 5s) with m445 leo 2000+ 180 esc
          4s2p m445
          and a video with some other props.
          Drammen rock City
          • d.a.v.e
            • Jan 2011
            • 230
            Did you happen to record speeds, run time, & handling with the different props? Which did you like best?
            • maxmekker
              • 466
              Sorry no speed recording.. run time with 4s2p 4000 , about 5 min. the 445 on 5s (2s+3s 4000) about 3min + The m445 is good, should be in every MG owners tool box. The prathers are nice props, but seems to make it bounch more than others. I will try it again with the 4s lipos once I get the cracked hull fixed. I have a prather 230 to, but that one is large and I burned my stock motor on it. the 42x55 was like , nahh. But then again I did not give it much run time since the m445 was great.
              Drammen rock City
              • d.a.v.e
                • Jan 2011
                • 230
                I'm still waiting on my Eagle Tree to see what my system is really doing but last night I tried a Prather 230 prop and the boat seemed really fast in a strait line but at the same time it appeared to loose a lot of speed in the turns. What characteristic is it that makes the boat turn better with one prop then another? What should I be looking for if I want to try and race the boat? The closest course to me is about 1.5hrs away so a lot of testing at that course is probably not going to happen, but I do have a nice pond about a mile from my house for testing.
                • Peacock8
                  • 97
                  I´m running the x642. I love it. Seems to run better than my 42-55. 4s2p setup. everything else stock.
                  Ørjan.
                  • maxmekker
                    • 466
                    I to liked the prather 230, and it's in my toolbox S/B. I loved the sound it made. But my stock motor gave in after only a few minut's.I was to bring it in to have a look at the temps, only one more pass,and then dead still in the water.
                    Since Darian said in the tread here he tried it on a stock setup , i thought i could test it on 5s with the the turnigy 180 esc. I was a fool to test in on 5s right away. I think I will try it on the leo and 4s, and if Darin reads here now maybe you could say if you just S/B it, ore did some altering to the pitch and size of the P230. Thanks.
                    Drammen rock City
                    • maxmekker
                      • 466
                      Ørjan.
                      Try the m445. I like that prop. But sadly I never got to test the 642 ore the other props I have now , on the stock motor.May I ask what lipos you have in the 4s2p? I tried the Zippy 45c 4000 4s
                      Drammen rock City
                      • Peacock8
                        • 97
                        Okay, I use Turnigy 5000mah 45c-90. They are great! Get about 10 minutes of good runtime :D
                        Ørjan
                        • maxmekker
                          • 466
                          nice, I only got 5+ with the zippy's. (first run, maybe they will loosen up ore I have to lower the cutoff)Mind posting a few pic's with the lipos in the hull ? hard to fit ?
                          here's mine
                          Drammen rock City
                          • Peacock8
                            • 97
                            It´s tight! But it fits. I moved the water outlet further back so it didn´t interfere with the battery placement. I can put both all the way into the sponson.
                            Ørjan.
                            • maxmekker
                              • 466
                              Now go get a video with the nano's. I'm Ordering the same one's. Zippys are cheap but not that good. They ballance nice at charge, but after the run, they are a little off. I figured, but had to try for the price.
                              Drammen rock City
                              • Peacock8
                                • 97
                                Yeah, maybe going to run later today if the weather holds up.
                                Ørjan
