OSE main site or swap shop...
Confused on what prop to start with?
So after playing with a few props for too long I suppose, I let some of the magic smoke out of my stock ESC, for some reason it will now only work with 1 4c attached but not 2x2c's in series or 2x4c in parallel? I ordered a new Sea King 180 & Eagle Tree system to attempt to avoid this issue again :)
With the upgrade to the ESC is the m445 the way to go or are there other suggestions?
Sorry no speed recording.. run time with 4s2p 4000 , about 5 min. the 445 on 5s (2s+3s 4000) about 3min + The m445 is good, should be in every MG owners tool box. The prathers are nice props, but seems to make it bounch more than others. I will try it again with the 4s lipos once I get the cracked hull fixed. I have a prather 230 to, but that one is large and I burned my stock motor on it. the 42x55 was like , nahh. But then again I did not give it much run time since the m445 was great.Drammen rock City
I'm still waiting on my Eagle Tree to see what my system is really doing but last night I tried a Prather 230 prop and the boat seemed really fast in a strait line but at the same time it appeared to loose a lot of speed in the turns. What characteristic is it that makes the boat turn better with one prop then another? What should I be looking for if I want to try and race the boat? The closest course to me is about 1.5hrs away so a lot of testing at that course is probably not going to happen, but I do have a nice pond about a mile from my house for testing.
I to liked the prather 230, and it's in my toolbox S/B. I loved the sound it made. But my stock motor gave in after only a few minut's.I was to bring it in to have a look at the temps, only one more pass,and then dead still in the water.
Since Darian said in the tread here he tried it on a stock setup , i thought i could test it on 5s with the the turnigy 180 esc. I was a fool to test in on 5s right away. I think I will try it on the leo and 4s, and if Darin reads here now maybe you could say if you just S/B it, ore did some altering to the pitch and size of the P230. Thanks.Drammen rock City
Try the m445. I like that prop. But sadly I never got to test the 642 ore the other props I have now , on the stock motor.May I ask what lipos you have in the 4s2p? I tried the Zippy 45c 4000 4sOriginally posted by Peacock8 View PostI´m running the x642. I love it. Seems to run better than my 42-55. 4s2p setup. everything else stock.
Ørjan.
Drammen rock City
nice, I only got 5+ with the zippy's. (first run, maybe they will loosen up ore I have to lower the cutoff)Mind posting a few pic's with the lipos in the hull ? hard to fit ?
here's mine
IMG_0082 (Medium).JPGIMG_0083 (Medium).JPGIMG_0084 (Medium).JPGDrammen rock City
