Bad Kitty! Stop bouncing!!!
  • Darin Jordan
    • 8332
    #61
    Originally posted by Diesel6401 View Post
    Hey Darin you think my rx antenna is out of the hull far enough? You know how short the antenna on the sr's are.
    The boats I have SR's in still have the RX mounted up under the deck where the antenna exists to get it as far up as possible. Just needs to not be shielded by any major portion of the hull and it should work. I've NEVER had an RX issue with these in boats. Others have.
    Darin E. Jordan - Renton, WA
      • 9479
      #62
      I use this stuff, it has saved a tactic rx and a esc:
      Same stuff I use bro!
      • Diesel6401
        Memento Vivere
        • 4203
        #63
        Thank you for the details. It's as high as it can go, I made a different mount for it to get it as close to the antenna hole is it could.
        - Diesel's Youtube
        - Diesel's Fleet
        • shotimes95
          • 101
          #64
          Mg help!!!
          Originally posted by igottalongone View Post
          Thanks Boomer...
          I'm running 45C 5000mah 2S Hyperion packs, the 642 I'm running is thinnned and cupped...
          Im running a s/b x642 and 2 7.4v 2s 45c 5400 mahOrion Carbon batteries and its not even close to running that fast. The motor is not as high pitched as in the video. I programmed it using the card even on high timing and it isnt even close to being that fast.
          When i programmed it i followed the instructions, it beeped i plugged the servo lead back in and no throttle but steering only. In order for the throttle to work, i must turn off the boat, disconnect the batteries and turn it all back on and it all works.
          What am i doing wrong? And one other thing, everytime i turn on the boat it beeps once, then sometimes it it beeps 2x4 beeps, not 1 beep and 5 after. I just contacted Horizon and there sending out a new esc. Can anyone help me please? Im so disappointed!!!
          • Diesel6401
            Memento Vivere
            • 4203
            #65
            Originally posted by shotimes95 View Post
            Im running a s/b x642 and 2 7.4v 2s 45c Orion Carbon batteries and its not even close to running that fast. The motor is not as high pitched as in the video. I programmed it using the card even on high timing and it isnt even close to being that fast.
            http://forums.offshoreelectrics.com/...ad.php?t=18337
            After you program and it beeps you have to disconnect the batteries before you plug it directly into the rx. You shouldn't just go from the program box directly to the rx while the power is still on. That's how I don it and it works for me. I ran 36mph on 4s and 46mph on 5s without changing anything other than the prop.
            - Diesel's Youtube
            - Diesel's Fleet
            • shotimes95
              • 101
              #66
              i gottalongones you tube video shows it running on 2s 5000mah and he says hes getting 46mph... is that true?
              • shotimes95
                • 101
                #67
                I just programmed it as u stated and it after programming, initially turning the boat back on, i get the initial beep, then followed by 5x2 beeps. Any ideas?
                Thanks
                • Diesel6401
                  Memento Vivere
                  • 4203
                  #68
                  Thanks
                  Did you read the link I posted about the beeps? Your not by accident plugging the lead into the rx upside down. I did that before with a SV and it just would constantly beep at me lol
                  - Diesel's Youtube
                  - Diesel's Fleet
                  • shotimes95
                    • 101
                    #69
                    Nope its in the right way. It beeps only 5 double beeps then stops and seems to work ok but im unsure...
                    • Diesel6401
                      Memento Vivere
                      • 4203
                      #70
                      If it works then its fine. If something was wrong it wouldn't work. Just my thoughts.
                      - Diesel's Youtube
                      - Diesel's Fleet
                      • shotimes95
                        • 101
                        #71
                        its just slower than my fastech... and it doesnt seem right
                        • Diesel6401
                          Memento Vivere
                          • 4203
                          #72
                          Is your throttle curve set to "LINEAR" and not "LOGARITHM"?
                          - Diesel's Youtube
                          - Diesel's Fleet
                          • shotimes95
                            • 101
                            #73
                            lipo
                            high cutoff
                            slowdown
                            brake off
                            timing high
                            linear curve
                            I read logarithm only goes 80% throttle
                            • Diesel6401
                              Memento Vivere
                              • 4203
                              #74
                              lipo
                              high cutoff
                              slowdown
                              brake off
                              timing high
                              linear curve
                              Yea it does, that's why I was asking.
                              - Diesel's Youtube
                              - Diesel's Fleet
                              • shotimes95
                                • 101
                                #75
                                it just must be a bad esc... No other reasoning. Clarification, program using card, esc beeps, disconnect batteries or turn off boat then disconnect batteries. then reconnect rx plug?
